    mod function doesn't work with variable or constant name
    Gcode meta commands
    • MathVundefined
      MathV
      Hi everybody,
      I am using the mod(,) function in a while loop and I noticed that the function doesn't work with the contstant "iterations" in it.
      Here is my while loop:
      while iterations < 1000
        if mod(iterations, 50) = 0
          M117 "mod function OK!"
        G4 P100
        continue
      The evaluation of mod(140,50) returns the proper value.
      If I create a global variable [name], set it to 140 (and check the assignment with M117) and evaluate mod(global.[name],50), it doesn't return any value.
      Is there somehing I missed?
      Thanks in advance.
        dc42 administrators @MathV
        @mathv it works OK for me, running in standalone mode, if I replace the M117 line with an echo command.
        It is a feature of DWC that if you send the same M117 message two or more times in succession, you only see the first one. So it also works for me if I replace the M117 line with this:
            M117 {"mod function OK! "^iterations}
        because then the message is different each time.
        MathVundefined 1 Reply Last reply Reply Quote 0
        • MathVundefined
          MathV @dc42
          @dc42 , Thanks for your feedback.
          I got this error message when I run it:
          Error: Failed to read code from macro test: Failed to evaluate "mod(iterations, 50) = 0": expected ','
          I am sure it is a very obvious mistake from me, but I can't find it.
            @mathv are you running RRF in CNC mode? If so, see my response to https://forum.duet3d.com/topic/24519/rrf3-3-meta-functions-don-t-work-when-in-cnc-mode.
