    After updating to 3.4.0beta2: faulty heater 1, -273.1C.
    Beta Firmware
    11
    121
    7.5k
    • juliannundefined
      juliann
      Hi
      After updating to 3.4.0beta2 I am getting a faulty heater 1, -273.1C.
      Duet 3 Mini 5+
      SBC Rpi4
      Toolboard v1.1
      High temp Slice Eng thermistor
      Any suggestions are very welcome.
      Thank you
      Julián.
      config.g:
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"duet3"                        ; set printer name
      M669 K1                                 ; CoreXY
      ;M552 P0.0.0.0 S1                        ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
       G4 S1   ;wait for expansion boards to start
      M569 P0.0 S0 D3                         ; physical drive 0.0 goes forwards
      M569 P0.1 S0 D3                         ; physical drive 0.1 goes forwards
      M569 P0.2 S0 D3                         ; physical drive 0.2 goes forwards
      M569 P0.3 S1 D3                         ; physical drive 0.3 goes forwards
      M569 P0.4 S1 D3                         ; physical drive 0.4 goes forwards
      M569 P20.0 S0 D3                         ; physical drive 0.5 goes forwards
      M584 X0.4 Y0.3 Z0.0:0.1:0.2 E20.0        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      ;LGX
      M92 X80.00 Y80.00 Z800.00 E406.19
      M906 X1000 Y1000 Z800 E800 I30               ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M566 X600.00 Y600.00 Z6.00 E600 P1          ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z1000.00 E3600.00     ; set maximum speeds (mm/min)
      M201 X3500.00 Y3500.00 Z100.00 E3600.00
      M208 X0 Y6 Z0 S1                                   ; set axis minima
      M208 X510 Y505 Z500 S0                             ; set axis maxima
      M574 X1 S1 P"20.io2.in"                           ; configure active high endstops
      M574 Y2 S1 P"io1.in"                           ; configure active high endstops
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      ;; BLTouch
      M950 S0 C"20.io0.out"                     ; Create a servo pin on io3
      M558 P9 C"20.io0.in" F120 H4 R0.1 T12000 A5 B0  ; set Z probe type to unmodulated and the dive height + speeds
      ;;IR Probe
      G31 P1000 X-28.00 Y-13.00 Z2.322       ; 0.6 SliceEng set Z probe trigger value, offset and trigger height, more Z means closer to the bed BLt
      M671 X-4.5:250:504.5 Y-4.52:505:-4.52 S5       ; Define positions of Z leadscrews or bed levelling screws
      M557 X5:480 Y20:485 S23.75:23.25                    ; define 5x5 mesh grid
      ; BED HEATER
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                     ; create bed heater output on out5 and map it to sensor 0
      M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S120                                        ; set temperature limit for heater 0 to 110C
      ;; BED Heater PID Tune JEN
      M307 H0 B0 R0.795 C325.9 D3.08 S1.00 V23.9
      M950 F0 C"20.out2+out2.tach" Q500                   ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"Hotend Fan" S0 H1 T45 L127   ; set fan 0 name and value. Thermostatic control turned on for Hotend
      ;M950 F1 C"20.out1+out1.tach" Q50000                   ; create fan 1 on pin out4 and set its frequency
      M950 F1 C"20.out1" Q600         ; create fan 1 on pin out4 and set its frequency
      M106 P1 C"Layer Fan" S0 H-1 L127       ; set fan 1 name and value. Thermostatic control is turned off
      M950 F2 C"!out3+out3.tach" Q25000                  ; create fan 1 on pin out4 and set its frequency
      M106 P2 C"Filter & Bottom Fans" S0 H-1 L255       ; set fan 1 name and value. Thermostatic control is turned off
      M950 F3 C"!out4+out4.tach" Q25000                  ; create fan 1 on pin out4 and set its frequency
      M106 P3 C"Exhaust Fan" S0 H-1 L255       ; set fan 1 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F1           ; define tool 0
      G10 P0 X0 Y0 Z0            ; set tool 0 axis offsets
      G10 P0 R0 S0               ; set initial tool 0 active and standby temperatures to 0C
      M308 S1 P"20.temp0" Y"thermistor" T500000 B4723 C1.196220e-7 ; PARA SLICE ENGINNERING HIGH TEMP
      M950 H1 C"20.out0" T1         ; create nozzle heater output on out2 and map it to sensor 1
      M307 H1 B0 S1.00           ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S270               ; set the maximum temperature in C for heater
      M307 H1 B0 R2.856 C126.3 D6.76 S1.00 V23.9			;JEN 24V
      M575 P1 B57600 S1;enable panelDue UART
      M501                                               ; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set tension thresholds and actions to run on power loss
      M404 N1.75 D0.6                                 ; Filament width and nozzle diameter
      ;DHT Sensor on IO4
      M308 S10 P"io4.out+io4.in" Y"dht22" A"Chbr Temp[C]"
      M308 S11 P"S10.1" Y"dhthumidity" A"Chbr Hum[%]"
      M591 D0 P3 C"20.io1.in" S1 ; R85:115 L24.15 E3.0 	; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      T0
      ;Input Shaping
      M593 P"zvdd" F40.5  ; use ZVD input shaping to cancel ringing at 40.5Hz
      ; Pressure Advance
      M572 D0 S0.01
      ; Set up Accelerometer
      M955 P20.0 I10 S1000 Q2000000
      m122:
      m122
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta2 (2021-08-03 12:43:05) running on Duet 3 Mini5plus WiFi (SBC mode)
      Board ID: BJHV4-F396U-D65J0-40KML-NT03Z-74PH4
      Used output buffers: 1 of 40 (18 max)
      Static ram: 102724
      Dynamic ram: 95020 of which 12 recycled
      Never used RAM 43956, free system stack 196 words
      Tasks: SBC(resourceWait:,2.5%,330) HEAT(delaying,0.0%,347) Move(notifyWait,0.0%,340) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,347) TMC(notifyWait,1.1%,106) MAIN(running,95.4%,536) IDLE(ready,0.1%,29) AIN(delaying,0.8%,264), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:10:00 ago, cause: power up
      Last software reset at 2021-08-03 14:59, reason: User, GCodes spinning, available RAM 43956, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 600735, completed 600734, timed out 0, errs 0
      Step timer max interval 1469
      MCU temperature: min 27.4, current 30.3, max 30.5
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 54579, writes 12, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 54579, writes 12, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 54579, writes 12, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 54578, writes 12, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 54579, writes 12, timeouts 0, DMA errors 0
      Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 54582, writes 9, timeouts 0, DMA errors 0
      Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 54581, writes 9, timeouts 0, DMA errors 0
      Date/time: 2021-08-03 15:19:12
      Cache data hit count 1311006805
      Slowest loop: 35.63ms; fastest: 0.07ms
      === Storage ===
      Free file entries: 10
      SD card 0 not detected, interface speed: 0.0MBytes/sec
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === Filament sensors ===
      Extruder 0: no data received
      === CAN ===
      Messages queued 5336, received 7249, lost 0, longest wait 5ms for reply type 6024, peak Tx sync delay 168, free buffers 17 (min 16), ts 3004/3003/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      State: 4, failed transfers: 1, checksum errors: 0
      Last transfer: 5ms ago
      RX/TX seq numbers: 22886/22886
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x10508
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.4-b2
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 21.53, max wait times: 36.8ms/5.3ms
      Codes per second: 0.09
      Maximum length of RX/TX data transfers: 3696/796
      m122 b20
      m122 b20
      Diagnostics for board 20:
      Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09)
      Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
      Never used RAM 2172, free system stack 2762 words
      Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.1%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.1%,342) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
      Last reset 00:05:13 ago, cause: power up
      Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 2
      Software reset code 0x0120 ICSR 0x00000000 SP 0x2000415c Task  Freestk 129 bad marker
      Stack: 00000544 00022ffc 00019b65 20003134 00016cff 20003134 000163d1 20000ed0 00000000 00000001 00008275 200071c8 200071c8 200071e0 00000000 20000f50 00011647 000223b8 00022474 00021ac8 00019b05 200071c8 200071c8 20000f50 000083ed 200071d8 000009c7
      Driver 0: position 0, 406.2 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 25503, writes 12, timeouts 0, DMA errors 0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter -3/7, peak Rx sync delay 211, resyncs 0/0, no step interrupt scheduled
      VIN: 24.2V
      MCU temperature: min 39.3C, current 40.8C, max 40.9C
      Ticks since heat task active 204, ADC conversions started 313198, completed 313197, timed out 0, errs 0
      Last sensors broadcast 0x00000002 found 1 209 ticks ago, loop time 0
      CAN messages queued 3648, send timeouts 0, received 2747, lost 0, free buffers 37, min 37, error reg 110000
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
      Accelerometer detected: yes, status: 00
      I2C bus errors 0, naks 3, other errors 0
      Interrupt 4 to 8us, poll 6 to 236us
      Driver 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      chrishammundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @juliann
        This post is deleted!
          dc42 administrators @juliann
          @juliann have you tried rebooting the main board, or powering the system off and on again? Sometimes when updating firmwares on several boards at the same time, the expansion boards can end up not being configured.
          Sergeundefined juliannundefined 2 Replies Last reply Reply Quote 0
          • Sergeundefined
            Serge @dc42
            @dc42 I have a similar issue.
            Duet3HC6 with SBC and toolboard 1.1LC.
            • juliannundefined
              juliann @dc42
              Yes, I did it several times and I always get the same error.
              Thanks!
                dc42 administrators @Serge
                @serge please try the suggestion that I made in my previous post.
                If that fails, try reverting to firmware 3.3 stable on the tool board - it's compatible with 3.4beta2 on the main board.
                dc42undefined Sergeundefined 2 Replies Last reply Reply Quote 0
                  dc42 administrators @dc42
                  @juliann you might need G4 S2 in config.f instead of G4 S1. If that doesn't help, try firmware 3.3 stable on the tool board.
                    @juliann, I've just noticed that your M563 command refers to heater 1 before you define heater 1 using M950. Try moving the M563 command until after you have defined the heaters and fans that it uses,
                    juliannundefined 1 Reply Last reply Reply Quote 0
                    • Sergeundefined
                      Serge @dc42
                      @dc42 Ok, thanks. How to do that ? I have a SBC.
                        @serge I think your issue is different from the one reported by @juliann , because you are getting a temperature reading. What exactly is the symptom?
                        Sergeundefined 1 Reply Last reply Reply Quote 0
                        • Sergeundefined
                          Serge @dc42
                          @dc42 when i do an emergency stop, the system does not restart. I have to do a sudo reboot of the SBC and it takes a very long time to restart. When I then update the firmware of the toolboard, the temperature indicated is 2000 °. I have to turn off the Duet and restart it. The indicated temperature is then 10 ° lower and very unstable.
                            @serge when the temperature reading is incorrect, what happens if you send:
                            M98 P"config.g"
                            Please post your config.g file.
                            • juliannundefined
                              juliann @dc42
                              Thank you @dc42, I already corrected both commands in config.g and the behaviour is the same.
                              Now I put v3.3 on the toolboard and the issue was fixed.
                              What I am missing by using v3.3 on the toolboard, can I still testing input shaping or this feature is only available in 3.4?
                              Thank you!
                                @juliann said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                                You can still test input shaping. Very little has changed in the expansion/tool board firmware.
                                • Sergeundefined
                                  Serge @dc42
                                  @dc42 Enregistrement d'écran 2021-08-03 à 17.18.41.mp4
                                  M98 P"config.g"
                                  Error: Operation failed (Reason: NullReferenceException in SimpleCode: Object reference not set to an instance of an object.)
                                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 18 2021 23:17:45 GMT+0200 (heure d’été d’Europe centrale)
                                  M550 P"Duet 3" ; set printer name
                                  M669 K1 ; select CoreXY mode
                                  G29 S1 ; Set Units to Millimeters
                                  M569 P20.0 S1 ; physical drive 20.0 goes forwards
                                  M92 X80.00 Y80.00 Z800.00 E836.00 ; set steps per mm
                                  M566 X2520.00 Y2520.00 Z480.00 E2520.00 ; set maximum instantaneous speed changes (mm/min)old 2520 for XY
                                  M203 X30000.00 Y30000.00 Z900.00 E3600.00 ; set maximum speeds (mm/min)
                                  M201 X3000.00 Y3000.00 Z320.00 E3600.00 ; set accelerations (mm/s^2)Old 3480 for XY
                                  M906 X1600 Y1600 Z1200 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M671 X0:200:409 Y-2:407:-2 S5 ; define positions of Z leadscrews or bed levelling screws
                                  M208 X410 Y400 Z400 S0 ; set axis maxima
                                  M574 X1 S1 P"20.io1.in" ; configure active high endstops
                                  M558 P8 C"20.io0.in" I1 H3 F600 69000 ; set Z probe type to unmodulated and the dive height + speeds
                                  G31 P1000 X-27.8 Y-12 Z1.668
                                  M556 S280 X-1.25 Y0 Z0 ; set orthogonal axis compensation parameters; set Z probe trigger value, offset and trigger height
                                  M557 X15:380 Y15:380 S35 ; define mesh grid
                                  M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                                  M307 H0 B0 R0.706 C344.2 D4.98 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                                  M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Hotend" ; configure sensor 1 as thermistor on pin 20.temp0
                                  M950 H1 C"20.out0" T1 ; create nozzle heater output on 20.out0 and map it to sensor 1
                                  M307 H1 B0 R5.925 C228.4:147.2 D9.34 S0.50 V24.0 ; disable bang-bang mode for heater and set PWM limit
                                  M143 H1 S285 ; set temperature limit for heater 1 to 285C
                                  M950 F1 C"20.out2" Q500 ; create fan 0 on pin 20.out2 and set its frequency
                                  M106 P1 C"Hotend Fan" S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
                                  M950 F0 C"20.out1" Q500 ; create fan 1 on pin 20.out1 and set its frequency
                                  M106 P0 C"Layer Fan" S0 H-1 ; set fan 1 value. Thermostatic control is turned off
                                  M955 P20.0 I24 S60 R10 ; Configure Accelerometer
                                  M956 P20.0 S60 A0 ; Collect accelerometer data and write to file
                                  ; EVA 2 / BMG / E3D V6
                                  M92 E830 ; set extruder steps per mm, 1.8 angle/step
                                  M906 E800 ; set extruder motor current (mA) and idle factor in per cent
                                  M404 N1.75 D0.4 ; Filament and nozzle diameter
                                  T0
                                  ; Custom settings
                                  ; Pressure Advance
                                  M593 F43.48
                                  M221 D0 S100
                                  M207 S0.4 F3000 Z0.00
                                  M200 D1.75
                                  M572 D0 S0.083
                                  M912 P0 S14
                                  dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
                                    @serge thanks, that error is one for @chrishamm.
                                    • Sergeundefined
                                      Serge @dc42
                                      Thanks, i have to send him the bug ?
                                        @serge said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                                        No, I have asked him to look at your post.
                                          @juliann, to help me diagnose this, please can you reload the new tool board firmware, then send M308 S1 with no further parameters, and report the response.
                                          • juliannundefined
                                            juliann @dc42
                                            @dc42 said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                                            M308 S1
                                            After reloaded the new 3.4b2 firmware on the toolboard the behaviour changed. The reading is not good but now the heater is active instead of faulty (and temp should be around 25C).
                                            M308 S1:
                                            M308 S1
                                            Sensor 1 type Thermistor using pin 20.temp0, reading 7.4, last error: sensor not ready, T:500000.0 B:4723.0 C:1.20e-7 R:2200.0 L:-5 H:-9```
