After updating to 3.4.0beta2: faulty heater 1, -273.1C.
Thanks both, please try test8.
test8 -Ok -
Test8-OK -
Thanks again! test9 is now available.
test9 -Ok -
don't know why but test 9 is seen by system as test8m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3+test8 (2021-08-21 14:00:53) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) -
@cadetc thanks, I forgot to update the version number text. The time (14:00) means you have the correct binary. Are the temperature readings OK?
yes -temp OK -
Thanks. Please can you both try file Duet3Firmware_TOOL1LC-34b2+2.bin from https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0.
PS - I've just updated that file because the version text didn't update.
OK! -
34b2+2.bin-OK -
m122 b121.0 Diagnostics for board 121: Duet TOOL1LC firmware version 3.4.0beta2+2 (2021-08-21 14:16:34) -
Thanks to both of you. It appears that this bug has gone away as mysteriously as it appeared.
there is definitely a difference between firmware 3.4b2 and 3.4b2+2
below is a screen with temperature reading for 3.4b2 and below for 3.4b2+2 -comparison made just now
m122 b121.0 Diagnostics for board 121: Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.4.0beta2+2 (2021-08-21 14:16:34) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) But all in all, the most important thing is that it's OK now,
Thanks
Thanks!
Temps in range with the latest build so I give it Thumbs Up!
And again, thank you for your time, dedication and work!
Hi all,
I updated my printer after vacation and noticed the same issue.
I have upped the LC1 to 3.4.0beta2+2 and readings are back within expected range.No recalibration done yet.
(I was not sure if there was a toolboard v1 reported or tested with the issue.)
Diagnostics for board 20: Duet TOOL1LC firmware version 3.4.0beta2+2 (2021-08-21 14:16:34) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) -
@dc42 Hello, sorry, i don't have receive notifications from this post that you have make for upgrading the firmwares.
I have try the 3.4b2+2 and now, i have the hotend sensor offline.
@dc42 Sorry for not following up further, I am currently on vacation away from my printer, but I am happy to try the builds when I am back in a week if it still makes sense.
