    Duet 2 Wifi Firmware Ender5 Plus
    Firmware installation
    • Btjundefined
      Btj
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03
      Hm!
      Has problems
      Has an Ender 5 Plus with Micro Swiss Direct + Bl touch
      Has made everything work except Homing and leveling
      Please someone who can help me
      my config file ..
      Configuration file for Duet WiFi (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Feb 03 2021 12:12:49 GMT-0500 (Eastern Standard Time)
      M550 P"Ender 5 Plus" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes backwards
      M92 X600.00 Y600.00 Z800.00 E156.47 ; set steps per mm
      M566 X1000.00 Y1000.00 Z80.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X8000.00 Y8000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X900.00 Y900.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z400 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; X min active high endstop switch
      M574 Y1 S1 P"ystop" ; Y min active high endstop switch
      Z-Probe
      M558 P9 C"^zprobe.in" H5 F100 T2000
      M950 S0 C"exp.heater3"
      G31 X-50 Y-11.02 Z-2,800 P25
      Home all Fil
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sat Jan 30 2021 10:03:31 GMT-0500 (Eastern Standard Time)
      G91 ; relative positioning
      G1 H1 X-350 Y-350 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X 150 Y 150 F500 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X150 Y150 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
        droftarts administrators @Btj
        @btj Post your homeall.g and homez.g. Following on from your other thread, and because you added a BLTouch after you created the configuration, I expect your homing files still expect a Z endstop. Your homing files should use G30 for Z, not a Z move. So your homez.g probably looks something like this:
        ; homez.g
        ; called to home the Z axis
        ; generated by RepRapFirmware Configuration Tool v3.3.0 on Wed Aug 04 2021 11:16:52 GMT+0100 (British Summer Time)
        G1 H1 Z-205 F1800 ; move Z down until the endstop is triggered
        G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
        When it should looks like this:
        ; homez.g
        ; generated by RepRapFirmware Configuration Tool v3.3.0 on Wed Aug 04 2021 11:19:43 GMT+0100 (British Summer Time)
        G1 X15 Y15 F6000 ; go to first probe point
          Please only create a single thread for your issue. Spamming multiple threads won't get you help any faster and in fact will only slow things down. Also please describe what you're actually trying to do and what isn't working. This thread is now locked.
