How to connect Duet2Eth to Repetier Server
Hello everybody, i'd like to connect my Duet2Eth to Repetier Server running on a RPi.
I think, it should work over a Ethernet connection. But i don't know how to set it up correctly.I don't like a connection over USB, because then the Duet is allways powered over the USB when Server is running.
has anybody done this already, and can share his settings in Repetier Server?
Thanks in advance. -
Update to Repetier Server 1.1.0 which already has native support for duet3D and RRF 3.3.
However, it has been tested with duet3 (6HC) boards in SBC mode, I don't know if it will work with the Duet2.
@marcossf I'm already running 1.1.0.
I know about the new native support. But i'd like to setup a "normal" connection...EDIT: Yesterday i have tried with tcp/ip -> no success.
i will try it with telnet today evening... -
@cosmowave For your information. It needs the Telnet activatet!
