    Leveling
    Firmware installation
    284
    • Btjundefined
      Btj
      I can not get to
      M557
      otherwise the probe misses the bed or it becomes only part of the bed
      • fcwiltundefined
        fcwilt @Btj
        @btj said in Leveling:
        I can not get to
        M557
        Lots of information missing there.
        How about telling us in greater detail what you are trying to do and what is not working.
        Thanks.
        Btjundefined 1 Reply Last reply Reply Quote 0
        • Btjundefined
          Btj @fcwilt
          @fcwilt
          M557 X310:20 Y330:20 S58:62
          Error: M557: bad grid definition: X range too small
          fcwiltundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @Btj
            @fcwilt
            Well according to that the Xmin is 320 and the Xmax is 20 - which doesn't make a lot of sense.
            And you may find the P parameter is preferable to the S parameter:
            From the M557 docs:
            *Saaa Probe point spacing (RepRapFirmware 1.19beta10 and later also support Saaa:bbb)
            Pnn or Pxx:yy (RRF 2.02 and later) Number of points to probe in the X and Y axis directions (alternative to specifying the probe point spacing)*
            • fcwiltundefined
              fcwilt @Btj
              @btj
              I forgot to mention M557 is used with G29 which is part of the mesh compensation feature for improving print quality.
              It is not leveling.
              Leveling, either manual or automatic, is done with G32.
              • Btjundefined
                Btj @fcwilt
                @fcwilt
                G32
                Error: No valid grid defined for bed probing
                  This post is deleted!
                    Please only create a single thread for each issue. This thread is now locked.
