    dsf-python 3.3.1 released (successor of pydsfapi)
    DSF Development
    • mfs12undefined
      mfs12
      Hallo,
      recently we decided to split the project DSF-APIs (https://github.com/Duet3D/DSF-APIs) into separate ones. Since this split the python part moved into dsf-python and can be found either at
      • https://github.com/Duet3D/dsf-python or
      • https://pypi.org/project/dsf-python
      Features:
      • split go and python repositories
      • official support of pip installer via the python package index
      Bugs:
      • fixed default socket file name
      • deleted flush function from intercept connection
      Official package can now be found at https://pypi.org/project/dsf-python/3.3.1/
      Help to make this project better and report bugs, ideas or wishes here.
      Visit me on github at https://github.com/mfs12/
      oozeBotundefined 1 Reply Last reply Reply Quote 1
      • oozeBotundefined
        oozeBot @mfs12
        @mfs12 We are testing this out (dsf-python) and need a gentle push to get started.. This is on a RPi 4b as the SBC. DSF-Python is installed.
        To test, we are using send_simple_code.py:
        #!/usr/bin/env python3
        Example of a command connection to send arbitrary commands to the machine
        Make sure when running this script to have access to the DSF UNIX socket owned by the dsf user.
        from dsf.connections import CommandConnection
        def send_simple_code():
            command_connection = CommandConnection(debug=True)
            command_connection.connect()
            try:
                # Perform a simple command and wait for its output
                res = command_connection.perform_simple_code("M115")
                print("M115 is telling us:", res)
            finally:
                command_connection.close()
        if __name__ == "__main__":
            send_simple_code()
        But receiving the following error:
        ModuleNotFoundError: No module named 'dsf.connections'; 'dsf' is not a package
        Any help would be appreciated. Once we can connect, I think we'll be in good shape. Thanks
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @oozeBot
          Replying once more as we got this example to work from within the dsf-python/example folder. That's good, as it proves it's working, but how can we get around the error when executing the script from another folder? That's the scenario tried from my previous post..
          mfs12undefined 1 Reply Last reply Reply Quote 0
          • mfs12undefined
            mfs12 @oozeBot
            @oozebot, you can install this package, and this is the recommended way except you plan to changes to dsf-python.
            You have two options
            system-wide:
            $ pip install dsf-python
            or for a single user:
            $ pip install --user dsf-python
            then you can import the module like any other as well.
            • mfs12undefined mfs12 pinned this topic
            • mfs12undefined
              mfs12
              New version released. Check...
              https://forum.duet3d.com/topic/26102/dsf-python-3-3-2-released
              • mfs12undefined mfs12 unpinned this topic
