    Dual heater circuit
    Using Duet Controllers
    chamber heating heated enclosure heater config
    • e4dundefined
      e4d
      Hello, I'm building a printer with a heated enclosure. I want it to be at 150°C in 30mn maximum. Currently I have 2x 750W heating resistors and it's not fast enough. I want to add one more but I can't keep them all connected during the print because of the power consumption.
      My idea is to have them separeted in 2 circuits (one with 1x 750W and the others with the other two) with 2 SSR. So I use the 3 of them at the begining and when I'm at the temperature set I disconnect one of the circuit and keep only one resistor to make sure I stay at the correct temp.
      I don't know how I can do that with the Duet config as I don't want to have to do it manually.
      My current config is this one, I use a Duet3 6CH :
      ; H1 Chamber
      M308 S1 P"0.temp1" Y"thermistor" A"Chamber" T100000 B4725 C7.06e-8  ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"0.out1" T1 Q10                                            ; create chamber heater output on out1 and map it to sensor 1
      M307 H1 B0 R0.092 C2302.8 D104.47 S1.00 V24.3                       ; PID parameters
      M141 H1                                                             ; map chamber to heater 1
      M143 H1 S200                                                        ; set temperature limit for heater 1 to 200C
      Could you please guide me in the right direction ?
        Phaedrux Moderator @e4d
        @e4d said in Dual heater circuit:
        The power consumption during the print should be substantially less than during the initial heat up. Furthermore, the consumption required to maintain the temp won't increase by adding another heater, since each heater would actually have to work less to maintain the same temp since the load is spread out over the 3.
        If you're already sure that consumption during the initial heat up isn't an issue, than I believe that consumption during the temperature maintenance phase won't be an issue either.
        • e4dundefined
          e4d
          I did power measurement and you are right about this, the power consumption reduced when regulating the temperature so it's an acceptable value. Thanks !
