    Variable "already exists"
    Gcode meta commands
    1.4k
    • DonStaufferundefined
      DonStauffer @Phaedrux
      @phaedrux Maybe a half dozen times a day. Usually I turn the machine off over night if I'm not printing anything long. I didn't know about M999 and I sort of thought emergency stop just kind of hung the machine and I had to turn it off anyway. Not sure. I haven't done it much.
        The emergency stop button basically runs M112 to do a full halt, and then resets the firmware with M999.
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M112_Emergency_Stop
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M999_Restart
          Was there anything unique to the time that it erased the config.g file?
          For the sake of completeness, could you share the config.g and the results of M122?
          DonStaufferundefined 2 Replies Last reply Reply Quote 0
            @phaedrux No, nothing unique I can think of. Just that message. I've attached config.g.bak to this message. It's the latest version of the file that I have. Its contents should be precisely what was in the file when it happened.
            [0_1628740265183_config.g.bak](Uploading 100%)
              @phaedrux
              8/11/2021, 10:52:45 PM M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DGM-9T6BU-FG3SN-6JKD0-3S06Q-9AY7D
              Used output buffers: 3 of 24 (15 max)
              Static ram: 23876
              Dynamic ram: 76604 of which 0 recycled
              Never used RAM 11080, free system stack 188 words
              Tasks: NETWORK(ready,10.1%,246) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,340) DUEX(notifyWait,0.0%,24) MAIN(running,83.8%,442) IDLE(ready,6.0%,29), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:00:12 ago, cause: software
              Last software reset at 2021-08-11 22:52, reason: User, GCodes spinning, available RAM 10856, slot 0
              Error status: 0x00
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 46.2, current 46.7, max 47.0
              Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/32/0, gc cycles 0
              Driver 0: position 0, standstill, SG min/max not available
              Driver 1: position 0, standstill, SG min/max not available
              Driver 2: position 0, standstill, SG min/max not available
              Driver 5: position 0, standstill, SG min/max not available
              Driver 6: position 0, standstill, SG min/max not available
              Driver 7: position 0, standstill, SG min/max not available
              Driver 8: position 0, standstill, SG min/max not available
              Driver 9: position 0, standstill, SG min/max not available
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2021-08-11 22:52:44
              Cache data hit count 470797477
              Slowest loop: 4.44ms; fastest: 0.17ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 0.9ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === DueX ===
              Read count 1, 4.85 reads/min
              === Network ===
              Slowest loop: 151.71ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                WiFi firmware version 1.26
                WiFi MAC address 84:f3:eb:83:47:be
                WiFi Vcc 3.36, reset reason Power up
                WiFi flash size 4194304, free heap 26496
                WiFi IP address 192.168.1.130
                WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
                Socket states: 4 0 0 0 0 0 0 0
              • fcwiltundefined
                fcwilt @DonStauffer
                @donstauffer said in Variable "already exists":
                @fcwilt I see what you mean. Create them with dummy values like zero, if they need to be created. That way the values only need to be tracked in one place. Not sure if you can create them without assigning a value. The documentation seems to say not.
                You would need to assign some placeholding value, like zero, I'm sure you could determine suitable values in each case.
                DonStaufferundefined 1 Reply Last reply Reply Quote 0
                  dc42 administrators @DonStauffer
                  I have my slicer set to insert a few variable definitions (var, not global) into the gcode files it produces. Works fine, except if I then upload and try to print another file without first restarting the duet, I get this "already exists" error, even though the original file completed and I started another.
                  Is that the way it's supposed to work?
                  I agree, it would make sense to treat local variables created in a print file the same as variables created in a macro file and remove them when the file completes or is cancelled. I will add a work item to fix this.
                    DonStauffer @fcwilt
                    @fcwilt The problem with conditionally defining local variables is:
                    "The scope of a local name is the remainder of the block in which it is declared."
                    So, this will produce "unknown variable":
                    if !exists(var.xxx)
                    	var xxx=0
                    set var.xxx=4
                    I'm trying to think of a workaround I can use right now, besides just making them globals.
                    • fcwiltundefined
                      fcwilt @DonStauffer
                      if !exists(var.xxx)
                      	var xxx=0
                      set var.xxx=4
                      Well that is not good news.
                      This my be a problem only @dc42 can solve.
                        DonStauffer @fcwilt
                        @fcwilt I've just been doing an M999 between jobs for now.
