common start and end gcode for all the slicer configurations
Good afternoon, I use Ideamaker as slicer and I have a configuration for every filament I use. Is there a way to make the start and end gcode to "call" a .g file to make ALL the different configuration have the same behaviour in the end and almost the same in the beginning? (I say almost boecause in the start gcode I have "common" parts as well as filament-related parts like the pressure advance).
Is there a way to do so?
Thanks!
@the_dragonlord yes, use the M98 command. In fact, RRF already calls start.g when you start printing from SD card, and end.g when a SD card print finishes with M0.
@the_dragonlord
For quite some time I have been using M98 P"print_begin.g" and M98 P"print_end.g" as the only user code in the slicer.
I also use the filament handling feature of DWC to deal with filament related settings such as bed temp and extruder temp.
I've used this approach with Simplify3D, Cura and PrusaSlicer with no problems.
I can provide more details if you wish.
@fcwilt said in common start and end gcode for all the slicer configurations:
@the_dragonlord
it would be great, thanks!
@dc42 said in common start and end gcode for all the slicer configurations:
excellent, thanks!
@the_dragonlord
Let's start with the filament handling feature of the DWC since it is an essential part of the way I do things to achieve a degree of slicer independence.
When you create a filament in the DWC the system creates three files for each filament:
- load.g
- unload.g
- config.g
The file config.g is the one that is important here. Note that this is not the main config.g file but a file with the same name unique to each filament.
The command M703 is used to invoke this config.g for the currently selected filament.
Here is an example of one of my filament config.g files:
M291 R"PLA - Generic - White" P"Configuring..." T0 M221 S100 D0 ; set extrusion multiplier G10 S190 R0 ; set extruder temps M140 S60 R0 ; set bed temps M291 R"PLA - Generic - White" P"Configuring - Done" T1
Here is my print_begin.g file. This file is invoked from the slicer using M98 P"print_begin.g", which is placed in the slicer location for user code to be executed at the start of a print.
; select tool and configure based on filament selected T0 ; select tool 0 so extruder commands below will work M703 ; configure selected filament (sets bed/extruder temps, extrusion multiplier) ; *** the following "sanity checks" test for required conditions to make my approach work *** ; check for selected filament if move.extruders[0].filament = "" M291 R"No Filament Selected" P"Cannot Continue" S2 T0 abort ; check bed heater active temp setting if heat.heaters[0].active = 0 M291 R"Bed Heater Active Temp = 0" P"Cannot Continue" S2 T0 abort ; check extruder heater active temp setting if heat.heaters[1].active = 0 M291 R"Extruder Heater Active Temp = 0" P"Cannot Continue" S2 T0 abort ; check if homed - allows homing (OK button) or canceling (CLOSE button) if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed M291 R"Printer has not been homed" P"Home and Continue?" S3 T0 G28 ; setup to print M291 R"Preparing to print" P"Please wait..." T0 G90 ; absolute moves G1 Z100 F1200 ; position for cleaning G1 X0 Y-145 F6000 ; position for cleaning M291 R"Heating Extruder & Bed" P"Please wait..." T0 M116 ; wait for temps to reach set points M291 R"Priming Extruder" P"Please wait..." T0 M83 ; insure extruder relative mode G92 E0 ; reset the extruder logical position G1 E10 F120 ; prime the extruder M400 ; wait for extruding to finish G92 E0 ; reset the extruder logical position M291 R"Clean Nozzle and Bed" P"Click OK to begin printing" S3 T0 G1 E-0.1 F120 ; retract to control oozing M400 ; wait for extruding to finish G92 E0 ; reset the extruder logical position M98 P"mesh_load.g" ; load height map
The code above is configured for the way I do things on my single tool printers. There are others ways you could do things, like priming the extruder.
The important parts are using T0 to select the tool, using M703 to invoke the selected filament config.g file and the "sanity checks" to verify the required conditions exist.
Check it over and let me know if you would like to see more of what I do.
@the_dragonlord
- load.g
- unload.g
- config.g
; select tool and configure based on filament selected T0 ; select tool 0 so extruder commands below will work M703 ; configure selected filament (sets bed/extruder temps, extrusion multiplier) ; *** the following "sanity checks" test for required conditions to make the my approach work *** ; check for selected filament if move.extruders[0].filament = "" M291 R"No Filament Selected" P"Cannot Continue" S2 T0 abort ; check bed heater active temp setting if heat.heaters[0].active = 0 M291 R"Bed Heater Active Temp = 0" P"Cannot Continue" S2 T0 abort ; check extruder heater active temp setting if heat.heaters[1].active = 0 M291 R"Extruder Heater Active Temp = 0" P"Cannot Continue" S2 T0 abort ; check if homed - allows homing (OK button) or canceling (CLOSE button) if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed M291 R"Printer has not been homed" P"Home and Continue?" S3 T0 G28 ; setup to print M291 R"Preparing to print" P"Please wait..." T0 G90 ; absolute moves G1 Z100 F1200 ; position for cleaning G1 X0 Y-145 F6000 ; position for cleaning M291 R"Heating Extruder & Bed" P"Please wait..." T0 M116 ; wait for temps to reach set points M291 R"Priming Extruder" P"Please wait..." T0 M83 ; insure extruder relative mode G92 E0 ; reset the extruder logical position G1 E10 F120 ; prime the extruder M400 ; wait for extruding to finish G92 E0 ; reset the extruder logical position M291 R"Clean Nozzle and Bed" P"Click OK to begin printing" S3 T0 G1 E-0.1 F120 ; retract to control oozing M400 ; wait for extruding to finish G92 E0 ; reset the extruder logical position M98 P"mesh_load.g" ; load height map
I'ts very interesting! If you have time give me more details, thanks!
