    Duet2 wifi RRF3 homing mixture
    739
    • Perttiundefined
      Pertti
      Hi! This is a new topic but the problems of my core xy printer are discussed here before.
      https://forum.duet3d.com/topic/24518/no-power-for-heater-h1/1
      https://forum.duet3d.com/topic/24428/tm-6600-connection-to-expansion-stepper-board/9
      Now I changed to RRF3.0 successfully.
      But when homing X then only the X moves. and when homing Y the X and y move the same distance ! Can´t figure out this. I think my problem started earlier in RRF2. Z is ok.
      other problems:
      The endstops started working when I copied previous config.g lines
      M574 Z0 S0
      M574 X1 Y1 S1
      Also bed heating does not start, (temp not rising)
      Heater 1 and Drive 0 are already lost.
      here´s my config.g
      ; generated by RepRapFirmware Configuration Tool v3.3.0 on Mon Aug 16 2021 09:36:00 GMT+0300 (Itä-Euroopan kesäaika)
      M550 P"My Printer" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      ; M569 P0 S1 ; physical drive 0 goes forwards
      ; M569 P1 S1 ; physical drive 1 goes forwards
      ; M569 P2 S1 ; physical drive 2 goes forwards
      ; M569 P3 S1 ; physical drive 3 goes forwards
      ; M569 P4 S1 ; physical drive 4 goes forwards
      ; M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P5 R0 T10:10:10:10 S0 ; T10:10:10:10 T2.5:2.5:5:5
      M584 X1 Y2 E3:4 Z5 ; set drive mapping z TM 6600
      ; M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      ; M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
      M92 X66.67 Y66.67 Z640.20 E837.00:144.00 ; set steps per mm (titan aero)
      ; M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      ; M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      ; M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      ; M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      ; M84 S30
      M906 X800 Y800 Z1600 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout ; Set idle timeout
      M208 X270 Y270 Z180 S0 ; set axis maxima
      ; M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop
      ; M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
      ; M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
      M574 Z0 S0 ; set active low and disabled endstops RRF2.
      M574 X1 Y1 S1 ; set active high endstops RRF2.
      M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
      M563 P1 D1 H2 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      Pertti
      “A winner is just a loser who tried one more time.”
      George M. Moore, Jr.
      • chrishammundefined
        chrishamm administrators @Pertti
        @pertti RRF v3 requires the individual endstop pins to be defined but the new commands for that are commented out. You'll need this instead of your current M574 calls:
        When you restart your board, check with M119 if the endstops states are correctly reported.
        Duet software engineer
        • Perttiundefined
          Pertti
          Here´s the result. I´m new with the RRF3 .
          Config.g
          ;M574 Z0 S0 ; set active low and disabled endstops RRF2.
          ;M574 X1 Y1 S1 ; set active high endstops RRF2.
          Endstops
          M119
          Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop
          -I do not use z probe
          Pertti
          • Perttiundefined
            Pertti
            Meanwhile I updated RRF3.0 to 3.3 by the "Duet2and3Firmware-3.3.zip" -file
            The wifi connection disappeared, this did not happen when uppdating from RRF2 to RRF3.0 . Did I do something wrong?
            I have had many problems with this board, should I get a new one or should I buy a Duet3? I´m aiming to build a duex printer some day.
            Pertti
              Phaedrux Moderator @Pertti
              @pertti said in Duet2 wifi RRF3 homing mixture:
              Occasionally the wifi server update can fail. To get it back, you need to reflash it by sending M997 S1 over the USB terminal.
              https://duet3d.dozuki.com/Wiki/FAQ#Section_Cannot_start_wifi_after_a_firmware_update
              I think you're just having some growing pains updating the firmware.
              You can send M98 P"config.g" in the gcode console to check for syntax errors.
              Perttiundefined 1 Reply Last reply Reply Quote 0
              • Perttiundefined
                Pertti @Phaedrux
                @phaedrux
                I sent M997 S1 over the USB , and it returned:
                Error: M997: File 0:/firmware/DuetWiFiServer.bin not found<LF>ok<LF>
                Ok, now the wifi connection was established.👍
                The LCD screen shows up but does not pass any commands and the console does not tell the IP or anything else.
                The x and y axes are engaged so that if You move x then x and y move and if You move y then x and y move. 🤔
                Pertti
                  In RRF 3.3 it will look for firmware bin files in the new firmware folder in the root of the SD card. This is to clean up the sys folder that was getting a bit crowded with bin files and config files. Manually placing the bin files into the firmware folder might be needed if they didn't get transferred over during the update. For that to happen, the update would need to be performed using DWC and uploading the full zip file.
                  But it sounds like you got the wifi updated and working now. But just to confirm, you can send M122 and check the main firmware version at the top of the report. It should be 3.3. The wifi firmware version is found near the bottom of the report and should be 1.26. DWC version should be 3.3 as well.
                  If you have a connection to DWC now, and you want to make sure you have all the needed files in the right place you can upload the full zip file again.
                  If you mean for the PanelDue, you need to have a command in config.g to enable it. M575 P1 B57600 S1 near the top of config.g will do it.
                  Is your printer a corexy?
                  It's configured as if it is. But is it actually?
                  • Perttiundefined
                    Pertti @Phaedrux
                    @phaedrux Many thanks again!
                    Unfortunately I´m occupied by my employer for a while. Coming back later.
                    Pertti
                    • Perttiundefined
                      Pertti @Pertti
                      @pertti
                      My printer is xy printhead and z bed (built on ruins of a Leapfrog Creatr)
                      I´m not 100% sure is it a Corexy. I commented M669 and now x and y move correctly! Maybe two z motors and drives are in Corexy, but I have only one.
                      M98 P"config.g"
                      HTTP is enabled on port 80
                      FTP is disabled
                      TELNET is disabled
                      Error: Bad command: Endstops (at the moment no endstops connected)
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                      WiFi firmware version 1.26
                      Pertti
                      • Perttiundefined
                        Pertti @Pertti
                        @pertti
                        Pertti
                        • Perttiundefined
                          Pertti @Pertti
                          @pertti
                          Now things get better😀 . The thermistor H1 came back(!) and H0 bed starts warming but gives a fault message of too slow temperature rising, same with H2. All thermistors seem to get power from the board.
                          Axes move nicely. There is still hope with this project, after all.
                          Pertti
                          • Perttiundefined
                            Pertti @Pertti
                            @pertti
                            I copied S values from my previous RRF2 configuration, now all heaters work fine!
                            M307 H0 B1 S120 ; S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
                            M308 S1 P"e0temp" Y"thermistor" T100000 B3950; B4138 ; configure sensor 1 as thermistor on pin e0temp
                            M308 S2 P"e1temp" Y"thermistor" T100000 B3950; B4138 ; configure sensor 2 as thermistor on pin e1temp
                            Pertti
                              Sound slike you've got most things working now. That's great.
                              Can you send M98 P"config.g" once more and report any errors? Also post your current config.g again.
                              • Perttiundefined
                                Pertti @Phaedrux
                                @phaedrux
                                M98 P"config.g"
                                FTP is disabled
                                TELNET is disabled
                                Error: bad model parameters
                                ; Z-Probe commented by user
                                ;M669 K1 ; select CoreXY mode PPremoved thus
                                M575 P1 B57600 S1
                                ; M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                ; G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                ; M557 X15:215 Y15:195 S20 ; define mesh grid
                                M307 H0 B1 S120 ;S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
                                M308 S1 P"e0temp" Y"thermistor" T100000 B3950;B4138 ; configure sensor 1 as thermistor on pin e0temp
                                M308 S2 P"e1temp" Y"thermistor" T100000 B3950;B4138 ; configure sensor 2 as thermistor on pin e1temp
                                Pertti
                                Phaedruxundefined 3 Replies Last reply Reply Quote 0
                                  You may need to add a space between the B3950 and ;B4138
                                  Send M308 S1 and M308 S2 in the console by itself to see what it reports.
                                  • Perttiundefined
                                    Pertti @Phaedrux
                                    @phaedrux said in Duet2 wifi RRF3 homing mixture:
                                    M308 S1
                                    M308 S1
                                    Sensor 1 type Thermistor using pin e0temp, reading 18.6, last error: sensor not ready, T:100000.0 B:3950.0 C:0.00e+0 R:4700.0 L:0 H:0
                                    M308 S2
                                    Sensor 2 type Thermistor using pin e1temp, reading 20.9, last error: sensor not ready, T:100000.0 B:3950.0 C:0.00e+0 R:4700.0 L:0 H:0
                                    Pertti
                                      Does that error still occur after fixing that missing space?
                                      • Perttiundefined
                                        Pertti @Phaedrux
                                        @phaedrux
                                        Yes, I´m afraid.
                                        M98 P"config.g"
                                        FTP is disabled
                                        TELNET is disabled
                                        Pertti
                                          I'm not sure which of these commands is sending that error message.
                                          Can you copy and past each of those lines one at a time to the gcode console? The offending line should produce the bad model parameters error.
                                          • Perttiundefined
                                            Pertti @Phaedrux
                                            @phaedrux
                                            I got it. This is the one and only line that sends the error message.
                                            Error: M307: bad model parameters
                                            Pertti
