    Object Cancel Plugin 1.0
    Plugins for DWC and DSF
    • Sindariusundefined
      Sindarius
      I have put together a new plugin that allows you to cancel objects in a simple 2D view.
      This is an initial release and there is a known issue where sometimes you have to resize the browser to get the build area to show up.
      You can get the release here
      https://github.com/Sindarius/ObjectCancelPlugin
      1 Reply Last reply Reply Quote 14
      • joekoundefined
        joeko
        hmm, i cant install it by upload&start. i get the errormessage that i can only upload one file. over system i can upload it but i cant see it in the plugin area.i have upload the zip file and firmware is 3.3
          jay_s_uk @joeko
          @joeko which zip file are you use?
          Do you not get the prompts to install the plugin?
          Are you standalone or SBC?
          joekoundefined 1 Reply Last reply Reply Quote 1
          • joekoundefined
            joeko @jay_s_uk
            @jay_s_uk said in Object Cancel Plugin 1.0:
            hallo,
            i use this
            https://github.com/Sindarius/ObjectCancelPlugin/archive/refs/heads/main.zip
            from here
            i found the link in the code button
            i have read your answer and have looked for an other version and found this
            https://github.com/Sindarius/ObjectCancelPlugin/releases/download/1.0.0/ObjectCancelPlugin-3.3.zip
            and with this i was able to install 🙂
            thx for your answer
