NPN sensor problem
Firmware installation
1.6k
  • undefined
    Petr K
    Hello guys,
    I use NPN NO sensor, probe test is OK, but command M119 writes: Z: at min stop, Z probe: at min stop, I tried all the combinations, but nothing worked. Can you help me please?
    ; generated by RepRapFirmware Configuration Tool v3.3.0 on Mon Aug 23 2021 16:43:59 GMT+0200 (Středoevropský letní čas)
    M550 P"BLV" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes forwards
    M569 P1 S0 ; physical drive 1 goes forwards
    M569 P2 S0 ; physical drive 2 goes forwards
    M569 P3 S0 ; physical drive 3 goes forwards
    M569 P4 S0 ; physical drive 4 goes forwards
    M584 M584 X0 Y1 Z2:4 E3 ; set drive mapping
    M671 X-10:155 Y300:155 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z3000.00 E6000.00 ; set maximum speeds (mm/min)
    M201 X1500.00 Y1500.00 Z100.00 E3000.00 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-20 Y-2 Z0 S1 ; set axis minima
    M208 X310 Y310 Z330 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
    M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop
    M574 Z1 S2
    M558 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
    G31 P0 X35 Y-4 Z0 ; set Z probe trigger value, offset and trigger height
    M557 X10:290 Y10:290 S56 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
    undefined undefined undefined 3 Replies Last reply 26 Aug 2021, 17:48 Reply Quote 0
    • undefined
      tecno @Petr K
      @petr-k said in NPN sensor problem:
      Try
      M558 P5 C"^!zprobe.in" H5 F120 T6000
      undefined 2 Replies Last reply 27 Aug 2021, 04:24 Reply Quote 2
      • undefined
        If it thinks it's triggered when it isn't, either it's picking up noise, or the trigger signal needs to be inverted/reverted.
        The ! means invert the signal. If you remove that what does it report? Does it detect a trigger still?
        The ^ on the pin name would enable the pullup resistor.
        How exactly do you have the probe wired?
        Can you confirm for us what your firmware version is? Post the results of sending M122 and M98 P"config.g"
        undefined 2 Replies Last reply 27 Aug 2021, 04:28 Reply Quote 0
        • undefined
          Petr K @tecno
          @tecno I will try it this afternoon, thanks.
          • undefined
            Petr K @Phaedrux
            I use Shottky diode BAT43 too and code I wil send this afternoon, thank you.
            undefined 1 Reply Last reply 27 Aug 2021, 05:06 Reply Quote 0
            • undefined
              fcwilt @Petr K
              @petr-k
              I recently tested a number of inductive sensors and capacitive sensors.
              Do you know the switching frequency of your device?
              The response time of such a sensor is related to it's switching frequency. The higher the frequency the faster the response.
              The best inductive sensors I tested had a switching frequency 3 kHz.
              The switching frequency of the two capacitive sensors I tested was 50 Hz which gave them a slow response time, so slow that I found them unsatisfactory.
              It's not that they don't work, it's just that you have to use a rather slow probing speed which makes creating high density height maps (20 x 20) a very slow and tedious experience.
              The advantage of capacitive sensors is that they can work with the various flexible plate build surface systems that use magnets.
              Inductive sensors can have problems with such systems.
              undefined 1 Reply Last reply 27 Aug 2021, 06:39 Reply Quote 0
              • undefined
                Petr K @fcwilt
                @fcwilt https://www.aliexpress.com/item/4000259928467.html?spm=a2g0s.9042311.0.0.27424c4dCecg3g I have this M20 NPN NO
                undefined 1 Reply Last reply 27 Aug 2021, 13:12 Reply Quote 0
                • undefined
                  fcwilt @Petr K
                  Well that indicates it is a inductive sensor but your previously posted image mentions a capacitive sensor.
                  And it seems to show that the switching frequency is 500 Hz - which should be fine.
                  Thanks.
                  • undefined
                    Petr K @Phaedrux
                    @phaedrux said in NPN sensor problem:
                    M122
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                    Board ID: 0JD0M-9P6M2-NWNS4-7J9DL-3SN6Q-TT2ZK
                    Used output buffers: 3 of 24 (11 max)
                    Static ram: 23876
                    Dynamic ram: 75028 of which 24 recycled
                    Never used RAM 15488, free system stack 184 words
                    Tasks: NETWORK(ready,13.4%,231) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,364) MAIN(running,86.2%,443) IDLE(ready,0.3%,29), total 100.0%
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:05:12 ago, cause: power up
                    Last software reset at 2021-08-26 17:54, reason: User, GCodes spinning, available RAM 15488, slot 2
                    Error status: 0x00
                    Step timer max interval 0
                    MCU temperature: min 12.6, current 20.6, max 21.0
                    Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: position 0, standstill, SG min/max not available
                    Driver 1: position 0, standstill, SG min/max not available
                    Driver 2: position 0, standstill, SG min/max not available
                    Driver 5: position 0
                    Driver 6: position 0
                    Driver 7: position 0
                    Driver 8: position 0
                    Driver 9: position 0
                    Driver 10: position 0
                    Driver 11: position 0
                    Date/time: 2021-08-27 16:46:06
                    Slowest loop: 2.88ms; fastest: 0.17ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 2.6ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 15.79ms; fastest: 0.00ms
                    HTTP sessions: 1 of 8
                    - WiFi -
                    Network state is active
                    WiFi firmware version 1.23
                    WiFi MAC address e8:db:84:92:3c:57
                    WiFi Vcc 3.40, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 24456
                    WiFi IP address 192.168.1.112
                    WiFi signal strength -66dBm, mode none, reconnections 0, sleep mode modem
                    Clock register ffffffff
                    Socket states: 0 4 0 0 0 0 0 0
                    M98 P"config.g"
                    HTTP is enabled on port 80
                    FTP is disabled
                    TELNET is disabled
                    Driver assignments: X0 Y1 Z2:4 E3, 3 axes visible
                    Warning: Macro file config-override.g not found
                    • undefined
                      Petr K @tecno
                      @tecno said in NPN sensor problem:
                      M119
                      Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                      undefined 1 Reply Last reply 27 Aug 2021, 15:04 Reply Quote 0
                      • undefined
                        fcwilt @Petr K
                        M119
                        Well if the sensor was not actually triggered remove the ! character from the M558 and test again.
                        undefined 1 Reply Last reply 27 Aug 2021, 16:07 Reply Quote 0
                        • undefined
                          dc42 administrators @Petr K
                          @petr-k if it's definitely a NPN NO sensor, then this command should work:
                          unless the senor has high leakage current. If that's the case then you might need to add a pullup resistor (e.g. 10K) between the sensor output and +3.3V or +5V. But I've not heard of this happening before.
                          Are you certain that it isn't a PNP output sensor?
                          undefined 2 Replies Last reply 27 Aug 2021, 15:39 Reply Quote 1
                          • undefined
                            Petr K @dc42
                            @dc42 This is writes on sensor LJ20A3-10-Z/BX. Ok I will try pull-up, thanks.
                            • undefined
                              Petr K @dc42
                              @dc42 pullup did nothing
                              • undefined
                                Petr K @fcwilt
                                @fcwilt said in NPN sensor problem:
                                Z probe value 1000, when triggered value is 0
                                undefined 1 Reply Last reply 27 Aug 2021, 16:12 Reply Quote 0
                                • undefined
                                  fcwilt @Petr K
                                  Was that with the ! character or without?
                                  undefined 1 Reply Last reply 27 Aug 2021, 16:25 Reply Quote 0
                                  • undefined
                                    Petr K @fcwilt
                                    @fcwilt M558 P5 C"^zprobe.in" H5 F120 T6000
                                    undefined 1 Reply Last reply 27 Aug 2021, 16:54 Reply Quote 0
                                    • undefined
                                      fcwilt @Petr K
                                      Well then it should work with the ! unless the the output voltage of the sensor simply isn't meeting the logic levels needed of the input.
                                      What is the forward voltage drop of that diode?
                                      Did you try it without the diode?
                                      As I recall the logic 0 voltage level for the input is appx 0.8 volts. It's possible the combination of the drop across the NPN transistor in the sensor and the diode fails to meet that logic 0 level.
                                      undefined 1 Reply Last reply 27 Aug 2021, 19:34 Reply Quote 1
                                      • undefined
                                        Petr K @fcwilt
                                        @fcwilt I try it without diode too, but it was the same, nothing changed.
                                        undefined undefined 2 Replies Last reply 27 Aug 2021, 19:36 Reply Quote 0
                                        • undefined
                                          fcwilt @Petr K
                                          Do you have a way to measure the voltage at the input to the board to verify the low (sensor triggered) and high (sensor not triggered) voltage levels
                                          undefined 1 Reply Last reply 28 Aug 2021, 08:15 Reply Quote 0
                                          1 out of 26
