Has anyone used the placeholders with Ideamaker in RRF?
@fcwilt said in Has anyone used the placeholders with Ideamaker in RRF?:
@the_dragonlord
Well the docs say for Bowden tube setups the starting point would be 0.5 and up.
It certainly cannot hurt to test a wider range.
Here is my first run and you can clearly see PA affecting the print - I think I tested in 0.05 steps - but it's been awhile.
I then went back and tested in 0.01 steps and 0.05 produced the smoothest seam.
In any case using 0.05 produces objects that meet all my needs even if my testing is seriously flawed.
what slicer are you using?
@the_dragonlord
Simplify3D
@the_dragonlord
Did you leave that echo command in and verify that the setting seemed to be changing as expected?
@the_dragonlord
Yes, I've runned the M572 command to verify
