    How to get the result of a M command
    Gcode meta commands
    • SIamundefined
      SIam
      I'm sure that I have something overlooked, so sorry for this question...
      How can I get the result of e.g. M573 p0 into a Variable or a File ?
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      Aitorundefined 1 Reply Last reply Reply Quote 0
      • Aitorundefined
        Aitor @SIam
        Good morning @siam ,
        Check the object models, in version 3.2 onwards DWC has a plugins to display them, you can also check this section https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware#main
        in your case it would be this: heat.heaters[0].avgPwm
        Best regards
        SIamundefined 1 Reply Last reply Reply Quote 2
        • SIamundefined
          SIam @Aitor
          @aitor said in How to get the result of a M command:
          Thank you that it was 😄
