Duet 3 mini 5 unresponsive
Hi
I just wired up the Duet 3 mini as per the ended 3 pro guide. Once it was wired up I went through the reprap config tool and updated the SD card. Then plugged the duet into USB and connected using simplify 3D and setup the Wi-fi. Everything was going really well until that point.
Now the Duet seems to have broken, when powered by USB it just has the 5v and 3.3v LEDs lit and if powered by 12v the Vfused and 12v leds also light up. Status LED does nothing unless I press reset then it comes on for 0.5 second. If I double click reset then status LED slowly fades between bright and dim. Neither the Wi-fi LED or the ACT do anything.
I can no longer connect with the board via simplify 3D as no port shows up. If I double click reset and get the fading status then I do get COM6 show up as the port but still can not connect.
I did try disconnecting all the end stops, motors and sensors.
Is the board broken? I have setup the duet 2 before and never had any issues.
@mikenative I have responded to your other post, so I am locking this one.
