Help duet 2 wifi is just not working correctly
My Duet controlled machine
1.9k
  • undefined
    po3plestorm
    Hello, I have a multitude of problems that I am completely dumfounded by when it comes to my board. I had a knock of duet 2 WIFI for awhile and was having issues with the thing heating up, I supposed I burned a chip out and so I just opted to buy a genuine board. That's where the problems started, the board is out of the box having the same issue and now even more. I'm fairly confident that its a software thing but Ill list off my issues and see if anyone has anything similar.
    So my first issue is that the nozzle does not heat up, it has a voltage on the leads but no heating at all, I've tried about 3 different heater cartages and nothing. I have also tried changing the resistance values but the ones I have are the ones listed for the heater cartage.
    My second Issue is that every time I update the config or any other files with the RRF config tool and upload them the machine just uploads everything then does nothing with them. Usually it asked to install them but for some reason nothing happens, even after restart. I have also tried to copy and paste the text from the config file into the one on the drive already and save it but still no luck.
    That last problem also is most likely causing my newest issue which is there the limit switches for homing are stuck in a low end config. No matter what I do to the config the printer thinks that the switches are in a low configuration for the location trigger. I have changed the config file over and over back and forth and no luck.
    All these issues are baffling to me as I have changed virtually nothing with the board. besides adding a new hot end, but the electronics are the same I installed the newest version of the firmware 3.3 and even tried going back to 3.0. still no change. I used the same anet a8 template for the RRF config tool that I always use and still no change. I have completely wiped the firmware multiple times now as well with the erase pin and did fresh installs and still nothing.
    Ill Include my config file but I dont imagine its very helpful. I now have two duet boards that im fairly certain are totally fine and I cannot get the software to work correctly.
    Any help is appreciated, thanks!
    config.g
    • undefined
      It sounds like you might be placing the config files in the wrong folder.
      All the config files, homing files, etc should be in the /sys folder on the SD card. Sometimes people accidentally upload the files to the gcode/jobs folder or the macros folder. They edit those files but the firmware is using the files in the system folder. Does that sound possible?
      Can you check the SD card on a PC to see where the files are actually located?
      Can you send M122 and M98 P"config.g" and post the results?
      There's nothing wrong with the config you posted that I can see. I just don't think it's actually being used by the Duet.
      undefined 1 Reply Last reply 2 Sept 2021, 00:15 Reply Quote 0
      • undefined
        po3plestorm @Phaedrux
        @phaedrux said in Help duet 2 wifi is just not working correctly:
        M98 P"config.g"
        here you go I dont know what caused that error on the one side, currently I have everything un plugged from the board so that might be it?
        I also Checked the SD card and the config files are being put in the right place
        Test.txt
        • undefined
          Just to make sure you have all the right files in all the right places I suggest you upload these two zip files, one at a time, reboot between each. Start with 3.0 again, and then 3.3. Confirm the firmware is correct with M115 after each.
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
          undefined 1 Reply Last reply 2 Sept 2021, 18:07 Reply Quote 0
          • undefined
            @phaedrux still nothing, no change. Im so lost, I also tried compleatly wiping the sd card again and installing from scratch and got a bunch of errors with the wifi not booting but I managed to fit those. now Im back to were I started.
            • undefined
              Can you be a bit more descriptive about where you're at now?
              Did the firmware update to 3.3? Are you able to confirm this in DWC?
              What exactly is the problem now? Can you show a video of it?
              @po3plestorm said in Help duet 2 wifi is just not working correctly:
              What exactly do you mean by this? Setting the endstop location in config.g is one part of it, but the actual direction of movement is configured in the homing files. Homeall.g homex.g homey.g homez.g
              -X should move left, +X should move right
              -Y should move to the nozzle to the front of the bed, +Y to the back.
              undefined 1 Reply Last reply 3 Sept 2021, 16:09 Reply Quote 0
              • undefined
                @phaedrux @phaedrux
                I installed the firmawares 3.0 then 3.3 just the way you said and nothing changed. The printer still wont install firmware or config files, but it does upload them. The printer will only home if I hold down the limit siwtches and release them like the signal is just inverted, but changing the high/low in the config wont do anything.
                Second the printer still wont heat up either the hot end or the bed, despite having voltage and having the correct resistances/values in the configuration.
                And now Im having the issue of the wifi module not starting. https://forum.duet3d.com/topic/11491/wifi-module-won-t-start/2
                this forum describes the issue and fixes it but only temporary, as it comes back every power cycle.
                so not only did nothing work it actually made it worse. Currently I unplugged everything from the board and the wifi module still wont turn on after a power cycle. So at this point I feel its a hard ware issue with the wifi module. But I contacted Filistruder and they said the board was tested before It was shipped to me which makes me think its not a hardware failure.
                • undefined
                  When you uploaded the 3.3 zip file, did it appear to be updating? Is that when you lost connection to the wifi? Or was it able to update? Did you confirm installed version with M115?
                  Can you show the exact gcode you're changing for this? If the pin is showing triggered when it shouldn't the pin can be inverted by adding a ! to the start of the pin name.
                  Having exact error messages would be helpful. It's possible the wifi module firmware didn't get updated along with the rest. If that's the case you'll have to manually flash it with the USB terminal by sending M997 S1.
                  I don't think there is a hardware issue here.
                  Please share the current config.g, and homeall.g files with us.
                  Please connect a USB cable and use the YAT terminal software to send commands to the duet so that you can try getting the wifi module going again. While you're there, also send M115 to check the installed firmware version. You can also test the state of the endstops with M119. Send it once with a switch depressed, and again when the switch isn't pressed and let us know the results.
                  undefined 1 Reply Last reply 3 Sept 2021, 16:51 Reply Quote 0
                  • undefined
                    @phaedrux so m115 outputs
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3␊
                    so its on 3.0, I think I went back to 3.0 after It didint work as thats the version I used on my old board with this same set up and it worked best.
                    this is the line here, x1, y1, and z1 for m574 changed high or low right? Neither one really does anything.
                    M574 X1 S1 P"xstop"
                    M574 Y1 S1 P"ystop"
                    M574 Z1 S1 P"zstop"
                    so Ill try the way you said and see if it works
                    and for the wifi module it says its connected or just idle and the light on the chip isint on.
                    • undefined
                      For the firmware, update to 3.3.
                      For the endstops, the X1 Y1 Z1 part should reflect where the endstop physically is on the printer. If the x endstop is on the left side, and -x moves to the left as it should, then it should be X1. The actual direction that the print head moves when you try to home is set in the homing files. The movement would be either - or +. You haven't posted those files so I don't know what you have in there. Maybe it's not set to move the right way.
                      But that doesn't effect when or how the endstop triggers electrically. If the endstop is showing triggered when the switch isn't actually pressed, and untriggered when it is (check with M119) then you can invert the signal by adding the ! to the pin name like this
                      M574 X1 S1 P"!xstop"
                      Can you send M122 in the terminal and copy and paste the results? Near the end of the report shows details on the wifi module.
                      Sending M997 S1 still isn't a bad idea to reflash.
                      Use M122 to see what firmware it's using.
                      Then use M552 S1 to see if it will enable and connect.
                      Use M587 to see a list of currently saved SSIDs
                      use M588 S"*" to clear all curently saved SSIDs
                      and then use M587 S"networkname" P"password" to re-add your SSID
                      undefined 1 Reply Last reply 3 Sept 2021, 18:00 Reply Quote 0
                      • undefined
                        @phaedrux ok so the homing cycle works flawlessly now, so thanks for that!
                        Now other other two problems are the wifi and the heaters.
                        For the wifi the m122 command returns:
                        and I have done that fix before and it just ends up having the same issue, Ill try it again but well see.
                        [13:55:57:570] === Diagnostics ===␊
                        [13:55:57:570] RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later␊
                        [13:55:57:570] Board ID: 0JD0M-9P6M2-NW4SD-6J1FA-3SJ6N-1AQMK␊
                        [13:55:57:572] Used output buffers: 1 of 24 (10 max)␊
                        [13:55:57:572] === RTOS ===␊
                        [13:55:57:572] Static ram: 30516␊
                        [13:55:57:572] Dynamic ram: 91636 of which 32 recycled␊
                        [13:55:57:572] Exception stack ram used: 288␊
                        [13:55:57:572] Never used ram: 8600␊
                        [13:55:57:572] Tasks: NETWORK(ready,1888) HEAT(blocked,1240) MAIN(running,3696) IDLE(ready,156)␊
                        [13:55:57:572] Owned mutexes:␊
                        [13:55:57:572] === Platform ===␊
                        [13:55:57:572] Last reset 00:21:21 ago, cause: software␊
                        [13:55:57:572] Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8416 bytes (slot 0)␊
                        [13:55:57:572] Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d␊
                        [13:55:57:572] Error status: 0␊
                        [13:55:57:572] Free file entries: 10␊
                        [13:55:57:572] SD card 0 detected, interface speed: 20.0MBytes/sec␊
                        [13:55:57:572] SD card longest block write time: 0.0ms, max retries 0␊
                        [13:55:57:572] MCU temperature: min 25.3, current 25.8, max 26.1␊
                        [13:55:57:572] Supply voltage: min 14.3, current 14.3, max 14.3, under voltage events: 0, over voltage events: 0, power good: yes␊
                        [13:55:57:572] Driver 0: standstill, SG min/max not available␊
                        [13:55:57:572] Driver 1: standstill, SG min/max not available␊
                        [13:55:57:572] Driver 2: standstill, SG min/max not available␊
                        [13:55:57:572] Driver 3: standstill, SG min/max not available␊
                        [13:55:57:586] Driver 4: standstill, SG min/max not available␊
                        [13:55:57:586] Date/time: 1970-01-01 00:00:00␊
                        [13:55:57:586] Cache data hit count 1680537180␊
                        [13:55:57:586] Slowest loop: 1.39ms; fastest: 0.11ms␊
                        [13:55:57:586] I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0␊
                        [13:55:57:586] === Move ===␊
                        [13:55:57:586] Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms␊
                        [13:55:57:586] Bed compensation in use: none, comp offset 0.000␊
                        [13:55:57:586] === MainDDARing ===␊
                        [13:55:57:586] Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0␊
                        [13:55:57:586] === AuxDDARing ===␊
                        [13:55:57:586] === Heat ===␊
                        [13:55:57:586] Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1␊
                        [13:55:57:586] === GCodes ===␊
                        [13:55:57:586] Segments left: 0␊
                        [13:55:57:586] Stack records: 1 allocated, 0 in use␊
                        [13:55:57:586] Movement lock held by null␊
                        [13:55:57:586] http is idle in state(s) 0␊
                        [13:55:57:586] telnet is idle in state(s) 0␊
                        [13:55:57:586] file is idle in state(s) 0␊
                        [13:55:57:586] serial is ready with "m122" in state(s) 0␊
                        [13:55:57:586] aux is idle in state(s) 0␊
                        [13:55:57:586] daemon is idle in state(s) 0␊
                        [13:55:57:586] queue is idle in state(s) 0␊
                        [13:55:57:586] autopause is idle in state(s) 0␊
                        [13:55:57:586] Code queue is empty.␊
                        [13:55:57:586] === Network ===␊
                        [13:55:57:586] Slowest loop: 0.18ms; fastest: 0.00ms␊
                        [13:55:57:586] Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)␊
                        [13:55:57:586] HTTP sessions: 0 of 8␊
                        [13:55:57:586] - WiFi -␊
                        [13:55:57:586] Network state is disabled␊
                        [13:55:57:586] WiFi module is disabled␊
                        [13:55:57:586] Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485␊
                        [13:55:57:586] Socket states: 0 0 0 0 0 0 0 0␊
                        [13:55:57:586] ok␊
                        [13:57:12:750] Warning: M522: Command is not supported␊
                        [13:57:12:750] ok␊
                        [13:57:16:957] Warning: M255: Command is not supported␊
                        [13:57:16:957] ok␊
                        [13:57:19:892] Warning: M225: Command is not supported␊
                        [13:57:19:892] ok␊
                        [13:57:22:645] Warning: M522: Command is not supported␊
                        [13:57:22:645] ok␊
                        [13:57:55:109] ok␊
                        [13:57:58:058] WiFi module is disabled␊
                        [13:57:58:058] ok␊
                        [13:58:04:563] Net mask: 255.255.255.0 ␊
                        [13:58:04:563] ok␊
                        [13:58:11:557] WiFi module is disabled␊
                        [13:58:11:557] ok␊
                        [13:58:15:037] ok␊
                        [13:58:18:270] WiFi module is disabled␊
                        [13:58:18:270] ok␊
                        [13:58:22:688] ok␊
                        [13:58:27:456] ok␊
                        [13:58:27:857] WiFi module started␊
                        [13:58:31:018] ok␊
                        [13:58:33:024] WiFi module is connected to access point ClarksonUniversity, IP address 128.153.181.60␊
                        [13:58:33:151] WiFi module is idle␊
                        [13:58:34:683] WiFi module is idle␊
                        [13:58:34:683] ok␊
                        [13:58:44:065] Warning: M223: Command is not supported␊
                        [13:58:44:065] ok␊
                        [13:58:58:978] === Diagnostics ===␊
                        [13:58:58:978] RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later␊
                        [13:58:58:978] Board ID: 0JD0M-9P6M2-NW4SD-6J1FA-3SJ6N-1AQMK␊
                        [13:58:58:981] Used output buffers: 1 of 24 (10 max)␊
                        [13:58:58:981] === RTOS ===␊
                        [13:58:58:981] Static ram: 30516␊
                        [13:58:58:981] Dynamic ram: 91636 of which 32 recycled␊
                        [13:58:58:981] Exception stack ram used: 320␊
                        [13:58:58:981] Never used ram: 8568␊
                        [13:58:58:981] Tasks: NETWORK(ready,1428) HEAT(blocked,1240) MAIN(running,3696) IDLE(ready,156)␊
                        [13:58:58:981] Owned mutexes:␊
                        [13:58:58:981] === Platform ===␊
                        [13:58:58:981] Last reset 00:24:22 ago, cause: software␊
                        [13:58:58:981] Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8416 bytes (slot 0)␊
                        [13:58:58:981] Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d␊
                        [13:58:58:981] Error status: 0␊
                        [13:58:58:981] Free file entries: 10␊
                        [13:58:58:981] SD card 0 detected, interface speed: 20.0MBytes/sec␊
                        [13:58:58:981] SD card longest block write time: 0.0ms, max retries 0␊
                        [13:58:58:981] MCU temperature: min 25.3, current 25.8, max 26.2␊
                        [13:58:58:981] Supply voltage: min 14.2, current 14.3, max 14.3, under voltage events: 0, over voltage events: 0, power good: yes␊
                        [13:58:58:981] Driver 0: standstill, SG min/max not available␊
                        [13:58:58:981] Driver 1: standstill, SG min/max not available␊
                        [13:58:58:981] Driver 2: standstill, SG min/max not available␊
                        [13:58:58:981] Driver 3: standstill, SG min/max not available␊
                        [13:58:58:981] Driver 4: standstill, SG min/max not available␊
                        [13:58:58:981] Date/time: 1970-01-01 00:00:00␊
                        [13:58:58:981] Cache data hit count 1921857042␊
                        [13:58:58:981] Slowest loop: 99.30ms; fastest: 0.10ms␊
                        [13:58:58:981] I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0␊
                        [13:58:58:981] === Move ===␊
                        [13:58:58:981] Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms␊
                        [13:58:58:981] Bed compensation in use: none, comp offset 0.000␊
                        [13:58:58:981] === MainDDARing ===␊
                        [13:58:58:981] Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0␊
                        [13:58:58:981] === AuxDDARing ===␊
                        [13:58:58:996] Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0␊
                        [13:58:58:996] === Heat ===␊
                        [13:58:58:996] Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1␊
                        [13:58:58:996] === GCodes ===␊
                        [13:58:58:996] Segments left: 0␊
                        [13:58:58:996] Stack records: 1 allocated, 0 in use␊
                        [13:58:58:996] Movement lock held by null␊
                        [13:58:58:996] http is idle in state(s) 0␊
                        [13:58:58:996] telnet is idle in state(s) 0␊
                        [13:58:58:996] file is idle in state(s) 0␊
                        [13:58:58:996] serial is ready with "m122" in state(s) 0␊
                        [13:58:58:996] aux is idle in state(s) 0␊
                        [13:58:58:996] daemon is idle in state(s) 0␊
                        [13:58:58:996] queue is idle in state(s) 0␊
                        [13:58:58:996] autopause is idle in state(s) 0␊
                        [13:58:58:996] Code queue is empty.␊
                        [13:58:58:996] === Network ===␊
                        [13:58:58:996] Slowest loop: 15.88ms; fastest: 0.00ms␊
                        [13:58:58:996] Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)␊
                        [13:58:58:996] HTTP sessions: 0 of 8␊
                        [13:58:58:996] - WiFi -␊
                        [13:58:58:996] Network state is running␊
                        [13:58:58:996] WiFi module is idle␊
                        [13:58:58:996] Failed messages: pending 0, notready 0, noresp 0␊
                        [13:58:58:996] WiFi firmware version 1.23␊
                        [13:58:58:996] WiFi MAC address 84:0d:8e:b3:01:f7␊
                        [13:58:58:996] WiFi Vcc 3.40, reset reason Turned on by main processor␊
                        [13:58:58:996] WiFi flash size 4194304, free heap 27880␊
                        [13:58:58:996] Socket states: 0 0 0 0 0 0 0 0␊
                        [13:58:58:996] ok␊
                        • undefined
                          So it looks like you're connected to an access point in there.
                          Do you have access to DWC yet? If so, please upload this zip file to the system tab to update all your firmwares and DWC files to 3.3 and send M122 again.
                          Do you have M552 S1 in your config.g?
                          • undefined
                            po3plestorm
                            OK so i think that fixed the wifi, right now its running and connected but the file keeps failing to upload cause of network error. For some reason the network here is really slow, even though its more than fast enough on my computer.
                            There is a m552 s1 command in my config
                            and this is the result from the m122 command
                            [14:54:07:644] === Diagnostics ===␊
                            [14:54:07:644] RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later␊
                            [14:54:07:646] Board ID: 0JD0M-9P6M2-NW4SD-6J1FA-3SJ6N-1AQMK␊
                            [14:54:07:646] Used output buffers: 2 of 24 (14 max)␊
                            [14:54:07:646] === RTOS ===␊
                            [14:54:07:646] Static ram: 23876␊
                            [14:54:07:646] Dynamic ram: 78984 of which 188 recycled␊
                            [14:54:07:646] Never used RAM 8512, free system stack 144 words␊
                            [14:54:07:646] Tasks: NETWORK(ready,13.6%,233) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,313) MAIN(running,86.2%,442) IDLE(ready,0.1%,29), total 100.0%␊
                            [14:54:07:646] Owned mutexes: WiFi(NETWORK) USB(MAIN)␊
                            [14:54:07:646] === Platform ===␊
                            [14:54:07:646] Last reset 00:28:30 ago, cause: power up␊
                            [14:54:07:646] Last software reset details not available␊
                            [14:54:07:646] Error status: 0x00␊
                            [14:54:07:646] Aux0 errors 0,0,0␊
                            [14:54:07:646] Step timer max interval 0␊
                            [14:54:07:646] MCU temperature: min 28.2, current 28.7, max 28.9␊
                            [14:54:07:646] Supply voltage: min 14.2, current 14.3, max 14.4, under voltage events: 0, over voltage events: 0, power good: yes␊
                            [14:54:07:646] Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/8/8, gc cycles 0␊
                            [14:54:07:646] Driver 0: position 7200, standstill, SG min/max not available␊
                            [14:54:07:646] Driver 1: position 7200, standstill, SG min/max not available␊
                            [14:54:07:646] Driver 2: position 0, standstill, SG min/max not available␊
                            [14:54:07:646] Driver 3: position 0, standstill, SG min/max not available␊
                            [14:54:07:646] Driver 4: position 0, standstill, SG min/max not available␊
                            [14:54:07:646] Driver 5: position 0␊
                            [14:54:07:646] Driver 6: position 0␊
                            [14:54:07:646] Driver 7: position 0␊
                            [14:54:07:646] Driver 8: position 0␊
                            [14:54:07:646] Driver 9: position 0␊
                            [14:54:07:646] Driver 10: position 0␊
                            [14:54:07:646] Driver 11: position 0␊
                            [14:54:07:646] Date/time: 2021-09-03 14:54:06␊
                            [14:54:07:646] Cache data hit count 4294967295␊
                            [14:54:07:646] Slowest loop: 18.10ms; fastest: 0.18ms␊
                            [14:54:07:646] I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0␊
                            [14:54:07:646] === Storage ===␊
                            [14:54:07:646] Free file entries: 9␊
                            [14:54:07:646] SD card 0 detected, interface speed: 20.0MBytes/sec␊
                            [14:54:07:646] SD card longest read time 2.7ms, write time 8.2ms, max retries 0␊
                            [14:54:07:646] === Move ===␊
                            [14:54:07:646] DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000␊
                            [14:54:07:681] === MainDDARing ===␊
                            [14:54:07:681] Scheduled moves 38, completed moves 38, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1␊
                            [14:54:07:681] === AuxDDARing ===␊
                            [14:54:07:681] Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1␊
                            [14:54:07:681] === Heat ===␊
                            [14:54:07:681] Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1␊
                            [14:54:07:681] === GCodes ===␊
                            [14:54:07:681] Segments left: 0␊
                            [14:54:07:681] Movement lock held by null␊
                            [14:54:07:681] HTTP is idle in state(s) 0␊
                            [14:54:07:681] Telnet is idle in state(s) 0␊
                            [14:54:07:681] File is idle in state(s) 0␊
                            [14:54:07:681] USB is ready with "m122" in state(s) 0␊
                            [14:54:07:681] Aux is idle in state(s) 0␊
                            [14:54:07:681] Trigger is idle in state(s) 0␊
                            [14:54:07:681] Queue is idle in state(s) 0␊
                            [14:54:07:681] LCD is idle in state(s) 0␊
                            [14:54:07:681] Daemon is idle in state(s) 0␊
                            [14:54:07:681] Autopause is idle in state(s) 0␊
                            [14:54:07:681] Code queue is empty.␊
                            [14:54:07:681] === Network ===␊
                            [14:54:07:681] Slowest loop: 200.84ms; fastest: 0.09ms␊
                            [14:54:07:681] Responder states: HTTP(0) HTTP(3) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions␊
                            [14:54:07:681] HTTP sessions: 1 of 8␊
                            [14:54:07:681] - WiFi -␊
                            [14:54:07:681] Network state is active␊
                            [14:54:07:681] WiFi module is connected to access point ␊
                            [14:54:07:681] Failed messages: pending 0, notready 0, noresp 1␊
                            [14:54:07:681] WiFi firmware version 1.23␊
                            [14:54:07:681] WiFi MAC address 84:0d:8e:b3:01:f7␊
                            [14:54:07:681] WiFi Vcc 3.40, reset reason Turned on by main processor␊
                            [14:54:07:681] WiFi flash size 4194304, free heap 25720␊
                            [14:54:07:681] WiFi IP address 128.153.181.60␊
                            [14:54:07:681] WiFi signal strength -69dBm, mode none, reconnections 0, sleep mode modem␊
                            [14:54:07:681] Clock register ffffffff␊
                            [14:54:07:681] Socket states: 2 0 0 0 0 0 0 0␊
                            [14:54:07:681] ok␊
                            undefined 1 Reply Last reply 3 Sept 2021, 19:32 Reply Quote 0
                            • undefined
                              po3plestorm @po3plestorm
                              @Phaedrux now that I look at that it says firmware 3.3 soooo i guess it did install? or already was 3.3 kinda weird, but it looks to be working. So now the only thing is the heating, the config has this
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 S706000000; configure sensor 0 as thermistor on pin bedtemp
                              M143 H0 S150 ; set temperature limit for heater 0 to 150C
                              M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                              M143 H1 S275 ; set temperature limit for heater 1 to 275C
                              Im using the listed settings from these two articles:
                              https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors
                              https://duet3d.dozuki.com/Wiki/M308
                              undefined 1 Reply Last reply 3 Sept 2021, 23:20 Reply Quote 0
                              • undefined
                                Your wifi server version is still out of date. Did you upload that complete zip file to the system tab in DWC yet?
                                undefined 1 Reply Last reply 5 Sept 2021, 18:40 Reply Quote 0
                                • undefined
                                  Phaedrux Moderator @po3plestorm
                                  S706000000
                                  Where did you get that value?
                                  undefined 1 Reply Last reply 5 Sept 2021, 18:20 Reply Quote 0
                                  • undefined
                                    @phaedrux so currently the firmware is as follows
                                    Board: Duet 2 WiFi (2WiFi)
                                    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
                                    Duet WiFi Server Version: 1.23
                                    and I dont know where I got that number, this is my current updated heater code
                                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 ; configure sensor 0 as thermistor on pin bedtemp
                                    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                    undefined 1 Reply Last reply 5 Sept 2021, 18:21 Reply Quote 0
                                    • undefined
                                      @po3plestorm here is my entire config.g file, the only issue I have now is getting the nozzle and heat bed to heat up
                                      ; Configuration file for Duet Maestro (firmware version 3)
                                      ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 02 2021 14:24:44 GMT-0400 (Eastern Daylight Time)
                                      M550 P"Ender 3 Pro" ; set printer name
                                      M918 P1 E4 F2000000 ; configure direct-connect display
                                      M552 S1 ; enable network and acquire dynamic address via DHCP
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P0 S1 ; physical drive 0 goes backwards
                                      M569 P1 S1 ; physical drive 1 goes backwards
                                      M569 P3 S0 ; physical drive 3 goes backwards
                                      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
                                      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X235 Y235 Z260 S0 ; set axis maxima
                                      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
                                      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
                                      M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin zstop
                                      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                      M557 X15:215 Y15:195 S20 ; define mesh grid
                                      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                                      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                                      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                                      • undefined
                                        Phaedrux Moderator @Phaedrux
                                        Wifi stil out of date
                                        What happens when you try to heat the bed or nozzle heater?
                                        Do you have the stock ender temp sensors or have you changed the hotend? Your hotend values looks like they are for an e3d temp sensor.
                                        undefined 1 Reply Last reply 5 Sept 2021, 18:48 Reply Quote 0
                                        • undefined
                                          @phaedrux So i cant get the wifi server to install fully, my internet here is bad and the connection isint stable enough to upload completely. Ill try doing it via sd card.
                                          I can get the heated bed to heat up and I tuned the PIDS on it. The nozzle is a new e3d himera, which was the whole beginning of this issue when I put it on and started updating esteps and junk. Im using the same heater cartage and have tried a bunch of brand new ones that I had never even used.
                                          2 out of 50
