Stuck in Delta Configuration - Solved
  • I posted and then used a prexisting file as the base for my config. That solved my issue of being stuck in a Delta config. Creating a new profile defaults to a Delta config.
    Tim
    Sounds like you are still running the old config.g file. You need to update either the config.g file or the whole zip file generated by configtool, through the Upload button on the Settings/ General page of the web interface.
  • Hi
    I appreciate the quick answer. I have edited my post to indicate that I copied one that I started from a presaved profile that was a cartesian setup. Sorry to waste your time.
    I am catching on to how this all comes together.
    Thanks
    Tim
