Configuration problems
@dave-parry said in Configuration problems:
Just noticed that the tool fan shows when the hot end is active and when hot end is off or standby is hidden.
I either need to hide it completely or get rid of the part fan control but have the tool fan control that fanThat tool fan display is controlled by the DWC.
It's just a way of having a single consistently named control in those cases where you might have multiple tools each with their own fan.
You can control the visibility of the actual part fan from the DWC.
Frederick,
Can you tell me where the conrol for fan visibilty is, because I cant see it.
also Thanks for your great patience and help. -
Found it. I was looking on the dashboard and its on the status.
Frederick,
also Thanks for your great patience and help.This is visible when you have selected the Job/Status display in the DWC.
See the item "Change Visibility"?
Yours looks different to mine. I dont have no fans option, just lists all the fans with a tick box for each. Also jobs and status are seperate tags.
Like this?
Status is under the Job category - that what I meant by Job/Status
I understand, and if I turn all the fans off in the tick box I get no fans message, Think I'm getting tired, Will carry on with calibration tomorrow. Thank you for your help. would'nt have got there without it.
