    Filament Material Changes without Load - Unload ???
    Firmware wishlist
    1.2k
    • SputnikOC3dundefined
      SputnikOC3d @fcwilt
      @fcwilt ty sir ...
      I will ponder this approach. tbh - at this time this looks a bit over my current rrf paygrade
      • fcwiltundefined
        fcwilt @SputnikOC3d
        @sputnikoc3d said in Filament Material Changes without Load - Unload ???:
        @fcwilt ty sir ...
        Well it's the simplest approach I can think of that doesn't require you to respond to a question every time you load/unload.
        Was there something about the code you did not understand?
        You already have the load/unload code.
        I just added a way to control if it is run or not.
        SputnikOC3dundefined 1 Reply Last reply Reply Quote 1
          SputnikOC3d @fcwilt
          @fcwilt
          Just looked your post over better - I get it now - duoh!
          So what I think youve outlined there is - I'd have a manual button/macro I can hit that will toggle on/off my load / unload scripts when I change a filament via dwc tool drop down option ...
          Kinda slick actually - I like this.
          fcwiltundefined 1 Reply Last reply Reply Quote 1
          • fcwiltundefined
            fcwilt @SputnikOC3d
            @fcwilt
            Exactly.
