Curious on G32 results
Hi all,
I finally got sensible and at least run a G32 before each print on my large delta.
The bed is 600mm round 8mm cast tooling plate, unrestrained sitting at the bottom of the machine.
I use an IR probe with the nozzle height checked weekly.The probe is conducted over a 400mm square build area that is a powder coated PEI spring steel magnetic plate.
When doing a G32 the output settles down after the initial couple of runs to the be as per the lines below providing the printer is not turned off.
At this time i'm printing close to 24x7, everything is good, just curious why the before numbers are different generally for the mean...9/7/2021, 9:57:21 AM Calibrated 6 factors using 14 points, (mean, deviation) before (-0.069, 0.088) after (-0.000, 0.087)
9/7/2021, 2:04:27 PM Calibrated 6 factors using 14 points, (mean, deviation) before (-0.032, 0.087) after (0.000, 0.084)
9/7/2021, 6:13:54 PM Calibrated 6 factors using 14 points, (mean, deviation) before (0.014, 0.080) after (-0.000, 0.076)
9/7/2021, 10:26:49 PM Calibrated 6 factors using 14 points, (mean, deviation) before (0.034, 0.085) after (0.000, 0.082)Thanks for any insight
