    Internet Connection Problems
    Duet Web Control
    • Damiano_SGundefined
      Damiano_SG
      I recently moved into my college dorm and I am unable to connect the duet 2 wifi to the internet as the wifi they use asks you to register the device via phone number. Is there a way to connect to the duet 2 wifi and use the DWC without connecting it to the internet?
      • o_lampeundefined
        o_lampe @Damiano_SG
        @damiano_sg I guess you will need a seperate router with DHCP between your PC and Duet2. Otherwise you might not get the same IP address everytime you log it in.
        Another issue: the dorm is probably flooded with WiFi traffic, they can interfere with the Duet and cause problems. A stable ethernet-cable connection is highly recommended.
          You could try using access point mode for the Duet. This creates a access point on the Duet that you connect to directly from your control device.
          https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M589_Configure_access_point_parameters
