what might stop daemon.g running?
@dc42 M122 includes:
Daemon: Buffered code: M106 P4 S1 L0.25 B0.2 H6 T35:36 C"encl" ; fan thermostatic ==> 92 bytes Executing macro daemon.g, started by system Number of flush requests: 1
I have to say I don't know how that fan definition got in there! It's not in the (current) daemon.g.
As implied, I have been fiddling with daemon.g while the print is running (which is presumably not very bright), and a version of daemon.g did have some fan commands, but not (intentionally) creating a thermostatic control on one - it had simple
M106 P4 S0.6
type things. Presumably at some point I've inadvertently saved something I shouldn't into daemon.g, and now therefore I don't actually know what is in the daemon.g it's running.Is there a way to kick daemon.g to tell it to to re-read the daemon.g file and start again, without upsetting a running print job?
@achrn I think deamon.g will be periodically "reloaded" (every 10 seconds).
@cosmowave said in what might stop daemon.g running?:
It's not reloading - it is still (two hours later) stuck on the same line of 'buffered code' which isn't in the current daemon.g (and probably hasn't been for at least 12 hours, because I haven't changed daemon.g since yesterday, though since I don't know how it got there, I can't be definitive about when it got there).
It's not a big problem - I can operate the vent manually, and do a M999 when the job completes.
@achrn Eventually it is possible to rename deamon.g in the sys folder. But i think it will not help with "unstucking" the system...
@achrn this is the section of the M122 report that I was interested in:
=== GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty
@dc42 OK:
=== GCodes === Segments left: 1 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X17.202999 Y17.684000 E0.256060" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is doing "M106 P4 S1 L0.250000 B0.200000 H6 T35:36 C"encl"" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty.
@achrn maybe rename daemon.g, give it a couple of minutes and then name it back
@jay_s_uk
Renaming it achieves nothing. Deleting it achieves nothing. Putting a new different one back in achieves nothing. In both the parts of M122 I've quoted up thread it stays stuck on doing an M106.Anyway, I'm now on layer 2496 of a 3180 layer print so I become less and less inclined to tamper in case I do something bad and it fails again (this being second attempt - first time it failed with some dodgy wiring, now replaced).
Just for completeness: Job completed. I issued M999 and it's working fine now.
Note to self. Don't muck with a running macro file.
