    Solved SBC not started after update
    Beta Firmware
    • com3
      com3 last edited by com3
      Hey,
      I recently updated my Duet 6hc+SBC from 3.2.2 to 3.4, or at least I tried.
      After the update I´ll get an error message "Failed to connect to duet, please check your connections".
      Checking with USB and 115 I´ll get follwing message
      SENDING:M115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta3 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-08-24 13:58:02
      journalctl -fu duetcontrolserver returns:
      pi@duet3:~ $ journalctl -fu duetcontrolserver
      -- Logs begin at Fri 2021-09-10 09:17:01 BST. --
      Sep 10 10:02:44 duet3 DuetControlServer[851]: [warn] Restarting transfer because        the Duet received a bad response (header)
      Sep 10 10:02:44 duet3 DuetControlServer[851]: [fatal] Could not connect to Duet        (Invalid protocol version 6)
      Sep 10 10:02:44 duet3 systemd[1]: duetcontrolserver.service: Failed with result        'protocol'.
      Sep 10 10:02:44 duet3 systemd[1]: Failed to start Duet Control Server.
      Sep 10 10:02:45 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=        100ms expired, scheduling restart.
      Sep 10 10:02:45 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j        ob, restart counter is at 10.
      Sep 10 10:02:45 duet3 systemd[1]: Stopped Duet Control Server.
      Sep 10 10:02:45 duet3 systemd[1]: duetcontrolserver.service: Start request repea        ted too quickly.
      Sep 10 10:02:45 duet3 systemd[1]: duetcontrolserver.service: Failed with result        'protocol'.
      Sep 10 10:02:45 duet3 systemd[1]: Failed to start Duet Control Server.
      sudo journalctl -u duetcontrolserver -e returns:
      pi@duet3:~ $ sudo journalctl -u duetcontrolserver -e
      Sep 10 10:02:43 duet3 DuetControlServer[838]: [info] Environment initialized
      Sep 10 10:02:43 duet3 DuetControlServer[838]: [fatal] Could not connect to Duet
      Sep 10 10:02:43 duet3 systemd[1]: duetcontrolserver.service: Failed with result
      Sep 10 10:02:43 duet3 systemd[1]: Failed to start Duet Control Server.
      Sep 10 10:02:43 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
      Sep 10 10:02:43 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
      Sep 10 10:02:43 duet3 systemd[1]: Stopped Duet Control Server.
      Sep 10 10:02:43 duet3 systemd[1]: Starting Duet Control Server...
      Sep 10 10:02:44 duet3 DuetControlServer[851]: Duet Control Server v3.2.2
      Sep 10 10:02:44 duet3 DuetControlServer[851]: Written by Christian Hammacher for
      Sep 10 10:02:44 duet3 DuetControlServer[851]: Licensed under the terms of the GN
      Sep 10 10:02:44 duet3 DuetControlServer[851]: [info] Settings loaded
      Sep 10 10:02:44 duet3 DuetControlServer[851]: [info] Environment initialized
      Upgraded DCS to 3.3, still not working.
      Sep 10 10:37:40 duet3 systemd[1]: Failed to start Duet Control Server.
      Sep 10 10:37:40 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
      Sep 10 10:37:40 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
      Sep 10 10:37:40 duet3 systemd[1]: Stopped Duet Control Server.
      Sep 10 10:37:40 duet3 systemd[1]: Starting Duet Control Server...
      Sep 10 10:37:40 duet3 DuetControlServer[2552]: Duet Control Server v3.3.0
      Sep 10 10:37:40 duet3 DuetControlServer[2552]: Written by Christian Hammacher fo
      Sep 10 10:37:40 duet3 DuetControlServer[2552]: Licensed under the terms of the G
      Sep 10 10:37:41 duet3 DuetControlServer[2552]: [info] Settings loaded
      Sep 10 10:37:41 duet3 DuetControlServer[2552]: [info] Environment initialized
      Sep 10 10:37:41 duet3 DuetControlServer[2552]: [warn] Restarting transfer becaus
      Sep 10 10:37:41 duet3 DuetControlServer[2552]: [fatal] Could not connect to Duet
      Sep 10 10:37:41 duet3 systemd[1]: duetcontrolserver.service: Failed with result
      Sep 10 10:37:41 duet3 systemd[1]: Failed to start Duet Control Server.
      Sep 10 10:37:41 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=
      Sep 10 10:37:41 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart j
      Sep 10 10:37:41 duet3 systemd[1]: Stopped Duet Control Server.
      Sep 10 10:37:41 duet3 systemd[1]: Starting Duet Control Server...
      Sep 10 10:37:41 duet3 DuetControlServer[2565]: Duet Control Server v3.3.0
      Sep 10 10:37:41 duet3 DuetControlServer[2565]: Written by Christian Hammacher fo
      Sep 10 10:37:41 duet3 DuetControlServer[2565]: Licensed under the terms of the G
      Sep 10 10:37:42 duet3 DuetControlServer[2565]: [info] Settings loaded
      Sep 10 10:37:42 duet3 DuetControlServer[2565]: [info] Environment initialized
      So it seems like the firmware update was succesful, but DCS is now on the wrong version or broken? How can I fix this (ideally without reflashing everything)?
      gloomyandy com3 2 Replies Last reply Reply Quote 0
      • gloomyandy
        gloomyandy @com3 last edited by
        @com3 What steps did you use to update the SBC?
        • com3
          com3 @com3 last edited by com3
          @com3
          I so I tried the stuff I found in other posts:
          sudo apt-get update
          sudo apt-get upgrade
          and:
          sudo apt update
          sudo apt upgrade duetsoftwareframework
          thats currently the situation here:
          Is there a way to extract all the sys files and macros (did not find anything on the SD-Card)? I could at least reflash it without losing everything 😕
          gloomyandy 1 Reply Last reply Reply Quote 0
          • gloomyandy
            @com3 If you want to use 3.4 you will need to switch to the unstable repo feed. See: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
            and the section on using beta software.
            com3 1 Reply Last reply Reply Quote 2
            • com3
              com3 @gloomyandy last edited by
              @gloomyandy thanks a lot, that worked!!
