How to compile the version 3.4 input shaping?
I was able to compile the firmware and generate the bin files for the RepRapFirmware-3.4-dev. However when I replace the RepRapFirmware-3.4-dev folder with RepRapFirmware-3.4-input-shaping (and keeping everything same) I cannot compile.
Can someone tell me how to compile RepRapFirmware-3.4-input-shaping or any other branch which implements input shaping
PS : I did rename them to RepRapFirmware before compiling
The log :
Invoking: Cross G++ Compiler arm-none-eabi-g++ -std=gnu++17 -D__SAME70Q20B__ -DRTOS -DDUET3_V06 -D_XOPEN_SOURCE -DUSE_CAN0 -I"C:\Eclipse\Firmware\CoreN2G" -I"C:\Eclipse\Firmware\CoreN2G\src" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70\asf\common\utils" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\cmsis\same70\include" -I"C:\Eclipse\Firmware\CoreN2G\src\arm\CMSIS\5.4.0\CMSIS\Core\Include" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70\SAME70" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70\asf" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\preprocessor" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\header_files" -I"C:\Eclipse\Firmware\CoreN2G\src\SAM4S_4E_E70\asf\sam\drivers" -I"C:\Eclipse\Firmware\RepRapFirmware\src" -I"C:\Eclipse\Firmware\RepRapFirmware\src\Hardware\SAME70" -I"C:\Eclipse\Firmware\RepRapFirmware\src\Networking" -I"C:\Eclipse\Firmware\RepRapFirmware\src\Networking\LwipEthernet\Lwip" -I"C:\Eclipse\Firmware\RepRapFirmware\src\Networking\LwipEthernet\Lwip\src\include" -I"C:\Eclipse\Firmware\DuetWiFiSocketServer\src\include" -I"C:\Eclipse\Firmware\FreeRTOS\src\include" -I"C:\Eclipse\Firmware\FreeRTOS\src\portable\GCC\ARM_CM7\r0p1" -I"C:\Eclipse\Firmware\RRFLibraries\src" -I"C:\Eclipse\Firmware\CANlib\src" -O2 -Wall -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fexceptions -nostdlib -Wundef -Wdouble-promotion -Werror=return-type -Wsuggest-override -fsingle-precision-constant "-Wa,-ahl=OutputMemory.s" -fstack-usage -MMD -MP -MF"src/Platform/OutputMemory.d" -MT"src/Platform/OutputMemory.o" -o "src/Platform/OutputMemory.o" "../src/Platform/OutputMemory.cpp" ../src/Storage/FileInfoParser.cpp: In member function 'GCodeResult FileInfoParser::GetFileInfo(const char*, GCodeFileInfo&, bool)': ../src/Storage/FileInfoParser.cpp:28:6: error: no match for 'operator!' (operand type is 'MutexLocker') 28 | if (!lock) | ^~~~~ ../src/Storage/FileInfoParser.cpp:28:6: note: candidate: 'operator!(bool)' (built-in) ../src/Storage/FileInfoParser.cpp:28:6: note: no known conversion for argument 1 from 'MutexLocker' to 'bool' src/Storage/subdir.mk:33: recipe for target 'src/Storage/FileInfoParser.o' failed make[1]: *** [src/Storage/FileInfoParser.o] Error 1 make[1]: *** Waiting for unfinished jobs.... Finished building: ../src/Storage/FileStore.cpp Finished building: ../src/Tools/Tool.cpp
@jazbaatbadalgaye the 3.4-input-shaping branch is obsolete now. Use 3.4-dev.
@dc42 Thanks! That compiled for Duet2 config (where I used CoreN2G-3.4-dev) but it fails for Duet 3 config where I used CoreNG-dev. Can you please suggest what version of CoreNG compatiable with RepRapFirmware 3.4 dev?
@jazbaatbadalgaye everything uses coreN2G in 3.4
@jay_s_uk Thanks! That worked like a charm however I had to include CoreESP8266 and LwipESP8266 in the working directory. @dc42 mentioned in another thread that those files are required if you're building DuetWiFiSocketServer but it gave me errors when I was trying to build CoreN2G-3.4-dev. The build errors were mitigated when I included CoreESP8266 and LwipESP8266 in working directory.
