CoreXY: moves not like expected
Hi Everyone,
At the moment i am stuck at setting up my Hevo. THe Problem is that the Extruders moves diffrent from the expected movement.
The Setup is as follows:
right-hand-System (X is left 0mm - right 290mm, y is front 0mm - back 290mm)
Endstop on X is at maximum (also configured on maximum, test shows Endstops works as expected)
Endstop on Y is at minimum (also configured on minimum, test shows Endstops works as expected)
I configured the system with help of this article; https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
So when I hit G1 H2 X10 the Extruder moves to +X+Y and when i hit G1 H2 Y10 the Extruder moves to +X-Y, so like it should after the guide.
When i now hit Home X, the Extruder moves to -X instead of +X, so he can't trigger the Endstop. But when i trigger the endstop by hand and then move move G1 X25, it moves like it should to the correct direction.
The behaviour of the Y-Axes is the same but invoked (moves to +Y instead o -Y, but after manual trigering the endstops it moves in correct direction)Hase anyone any suggestion what could be the problem here?
@reneberlin1511 post the contents of homex.g and homeall.g
I will paste them when i come home, But you are right it sounds like there can be the problem
Share full config.g too please, since if the homing files look correct we'd ask for that next anyway.
i found the mistake. it was an incorrect homex.g and homeall.g
Thanks for the Help
