    Home Z axis with IR probe
    • Edkirk
      Edkirk last edited by
      I have a CoreXY and using Duet Wifi with version 1.19.2 using switches on all three axis for primary homing which is working great. I home to X0 Y0 Z0. I want the print head to move to the center of the print area (X200 Y150) then Z probe using the IR probe to set final distance for first layer of print. I am sure I have seen the G code instructions on how to set up this move but I can't find it again. I don't want to do any kind of bed leveling at this time, my printer holds a very stable level bed after I level it using the old fashioned piece of paper method. Could someone please post the instruction or direct me to it.
      PS I have the IR Probe mounted, wired and working, the red LED comes on when it is about 5mm from the bed.
      Thanks, Ed
      • number40fan
        number40fan last edited by
        Look at the HomeZ section for the Cartesian printers.
        https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer
        • Edkirk
          Thanks, I will check it out.
          Ed
