    Ender 3 + bltouch configuration.
    Firmware installation
    • the-bigundefined
      the-big
      Hey all.
      I updated my RRF from 2.2 to 3.3.
      But it seems some problems with bltouch and heaters and fan too.
      1. When I try to home z it goes down without triggering the prob.
      2. the heater of bed not heat
      • Error: Heater 0 fault: temperature rising much more slowly than the expected 1.3°C/sec
      1. i can see only 1 fan on DWC insted of 3 i had on RRF 2.2
      config.g (of 3.3)
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 16 2021 18:03:06 GMT+0300 (שעון ישראל (קיץ))
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Ender 3"                                ; set printer name
      M918 P1 E4 F2000000                            ; configure direct-connect display
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S0                                     ; physical drive 0 goes backwards
      M569 P1 S0                                     ; physical drive 1 goes backwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E98.20               ; set steps per mm
      M566 X600 Y600 Z60.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z600.00 E6000.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z120.00 E5000.00          ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E9000 I50                  ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X235 Y235 Z260 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; set endstops controlled by probe
      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-51 Y-12 Z1.55                           ; set Z probe trigger value, offset and trigger height
      M557 X3:180 Y25:210 S20                        ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S80                                   ; set temperature limit for heater 0 to 150C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S275                                   ; set temperature limit for heater 1 to 275C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1:0 T45                            ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      old config.g (RRF 2.2)
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 27 2020 18:34:20 GMT+0300 (שעון ישראל (קיץ))
      M566 X600.00 Y600.00 Z60.00 E300.00                ; set maximum instantaneous speed changes (mm/min)
      M906 X800 Y800 Z800 E900 I50                       ; set motor currents (mA) and motor idle factor in per cent
      M574 X1 Y1 S1                                      ; set active high endstops
      M307 H3 A-1 C-1 D-1                             ; disable heater on PWM channel for BLTouch
      M558 P9 H3 F120 T6000 A5 S0.003 B1 R0.1                            ; set Z probe type to bltouch and the dive height + speeds
      M557 X3:180 Y25:210 p4:4                       ; define mesh grid
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 P0 T98801 B3950 R4700                          ; set thermistor + ADC parameters for heater 0
      M143 H0 S80                                        ; set temperature limit for heater 0 to 80C
      M308 P1 T98801 B3950 R4700                          ; set thermistor + ADC parameters for heater 1
      M143 H1 S250                                       ; set temperature limit for heater 1 to 250C
      M106 P0 S0 I0 F20 H-1                              ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F20 H1 T45                           ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F20 H1:0 T45                         ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M501                                               ; load saved parameters from non-volatile memory
      M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      T0                                                 ; select first tool
      jnofsingerundefined 1 Reply Last reply Reply Quote 0
      • jnofsingerundefined
        jnofsinger @the-big
        @the-big
        I would verify the exp.heater3 pin is in use for the BLTouch. I am using heater7 otherwise it is the same. does it work differently when you "homeall" vs "homez"?
        the heater rising too slowly is an known message and you can fix it by PID tuning (the better explanation is on the duet website)
        My fan line is pretty similar to yours other than using S1.0 instead of S1 (doubt that would make a difference). Do the fans still work though?
        the-bigundefined 1 Reply Last reply Reply Quote 0
        • the-bigundefined
          the-big @jnofsinger
          @jnofsinger
          Thank you for replay.
          1. I solved this problem as the homeall.g and homez.g was broke. Now all work fine.
          2. May you post link for me. This is the only problem prevent me the print.
          3. Should I see it on control?
            Were you able to PID tune your bed heater?
            https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
