DWC file manager modification proposal
it was to propose that this modification to how DWC works be studied.
In my particular case, I use Duet's SD as a "library" for the gcode files that I print, and I have quite a few stored, over 500, arranged in folders over 200 folders ...
The day has come that I want to clean the SD, deleting the oldest ones, the problem I have encountered is that what could be a simple operation ... select all the folders that I want to delete and with the right mouse button Deleting them becomes a hassle, since I can't delete the folder if I don't empty it before ... This is fine as a security measure, to avoid accidental deletions, but it becomes a hassle if you want to delete about 150 folders with two or three files each ... you have to go folder by folder emptying it ...
My proposal would be that the folders could be deleted even if they had files ... as a security measure for accidental deletions, I see two options, there will be more ... than when you select all the folders to delete, if they are not empty, I will skip a message warning .... or an option in the Duet configuration, where this security measure is not taken into account, that NOT empty folders can be deleted
