    Non-smooth upgrade of DWC 3.3.0 -> 3.4-beta4
    Duet Web Control
    • ÖrjanEundefined
      ÖrjanE
      When upgrading my Maestro firmware and DWC to 3.4-beta4, I encountered a few problems:
      1. First, I upgraded by uploading both DuetMaestroFirmware.bin and DuetWebControl-SD.zip to the system folder via the web interface (as one operation). The firmware upgraded nicely, but DWC was not updated; the zip-file was simply stored in the system directory. DWC remained at 3.3.0.
      2. Second try; I uploaded DuetWebControl-SD.zip again, this time alone. Now it started unpacking files, but the process was interrupted because the connection was temporarily dropped. Repeated this a few times with the same result. DWC was still reported as 3.3.0.
      3. Third try. Removed the sd-card and inserted it into my computer, unzipped the contents of DuetWebControl-SD.zip into the www-directory on the card. This proved successful, DWC now runs 3.4-beta4.
      Follow up question: Does DuetWebControl-SD.zip contain everything that should be in www? I.e. can I erase everything in www and unzip to get a pristine www?
        jay_s_uk @ÖrjanE
        @örjane yes, duetwebcontrol-sd is everything you need to go in the www folder
        ÖrjanEundefined 1 Reply Last reply Reply Quote 0
        • ÖrjanEundefined
          ÖrjanE @jay_s_uk
          @jay_s_uk Thanks!
