    problem with stringing
    • lui2004
      lui2004 last edited by lui2004
      Hi
      i have problems to remove stringing.
      I have an Ender5 with all metal hotend with Micro swiss DD
      my Thermistor is a Semitec 104GT-2
      my settings for Frimware retraction is:
      M207 P0 S0.80 R0 F2100 T2100 Z0 ; Firmware Retraction
      PLA Brand is German RepRap
      Nozzle Temp: 195°C
      Bed: 55°C
      thats a picture from retraction print:
      https://abload.de/img/20211003_151006l0jta.gif
      if you need some other configs tell it i will post it
      thanks
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @lui2004 last edited by Stephen6309
        @lui2004 Increasing retraction distance and feed rate should help.
        My E3DV6 on a BMG direct drive, I use: M207 S1.5 F6000 R0 Z0.03 ; firmware retraction
        If you have a bowden, it needs more retraction distance, due to the slack in the tube.
        lui2004 1 Reply Last reply Reply Quote 0
        • lui2004
          lui2004 @Stephen6309 last edited by
          @stephen6309
          i have a Direct Drive from Micro Swiss
          • Stephen6309
            @lui2004 Then you need to increase the retraction (S) and increase the feedrate (F) if needed. It appears the 0.80 retraction isn't enough.
