    Bed PID tuning warning message
    Using Duet Controllers
    • wouldstain
      wouldstain last edited by
      Just looking for a little insight on the meaning of this...
      Ran bed PID tuning after converting to MRW kinematic mount kit.
      It took several hours to complete but with a warning message.
      Warning: heater behaviour was not consistent during tuning
      Auto tuning heater 0 completed after 3 idle and 25 tuning cycles in 11953 seconds. This heater needs the following M307 command:
      M307 H0 B0 R0.344 C393.5 D30.24 S1.00 V24.1
      Edit the M307 H0 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
      What does this mean and is it something I should be concerned with? The Railcore documentation indicates that the bed PID tuning should take more around 30 minutes not 3+ hours..
      running DWC 3.3 w/ RRF 3.3
      • T3P3Tony
        T3P3Tony administrators @wouldstain last edited by
        @wouldstain beds do take longer to tune however that is a bit crazy, was there a lot of variation in ambient temperature at points during the tuning cycle?
        www.duet3d.com
        wouldstain 1 Reply Last reply Reply Quote 0
        • wouldstain
          wouldstain @T3P3Tony last edited by
          @t3p3tony Very little. In fact, I've got the MRW top cover on it so chamber temp is somewhat less impacted by outside ambient temperature.
          • T3P3Tony
            @wouldstain will have to ask @dc42 what he makes of the "heater behaviour was not consistent..." message. did you happen to get a screenshot of the temperature graph?
            www.duet3d.com
            • wouldstain
              @t3p3tony I did not as it ran for a fairly long time. If there's a way to get sample logs out of it I'd be happy to run it again and provide data.
