    Add Polar Co-ord machine movement buttons to DWC Dash
    Duet Web Control
    • CNCModeller
      CNCModeller last edited by
      Hi All,
      Is there any way for me to add a couple of extra rows to the machine movements section of the DWC dashboard. I'm running a polar machine and it'd be really useful to have radius and rotation movement available directly on the dash.
      I already have this on the printers display, but it'd be useful on the DWC dash too. I know I can create macros, but that'd be cheating 😉
      Any constrictive thoughts gratefully received.
      Cheers
      Barry M
      Polar Printer Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      Wanhao D5S & K40 Laser, Duet2 TBD
      https://www.youtube.com/CNCModellerUK
      MintyTrebor 1 Reply Last reply Reply Quote 0
      • MintyTrebor
        MintyTrebor @CNCModeller last edited by
        @cncmodeller I've no experience with polar machines, but as long as you know what commands are issued for the movement, you can add extra buttons to a movement panel using BtnCmd.
        Example:
        You can add as many/few as you need. Each button can issue a gCode command or run a macro. They can be re-sized as required & icons can be changed.
        NodeDSF - Native Node-Red integration with Duet boards.
        BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
        ReleaseMgr - Duet update info inside DWC.
        Repo
        CNCModeller 1 Reply Last reply Reply Quote 0
        • CNCModeller
          CNCModeller @MintyTrebor last edited by
          Thanks @mintytrebor looks like just the trick. I'll check it out 🙂
          Wanhao D4S: Duet2
