    SBC bug? Scope rules for while construct in macros?
    Gcode meta commands
    rrf3
    • Gixxerfast
      Gixxerfast last edited by Gixxerfast
      Hi!
      There seem to be different scope rules for the while construct dependig if you run them in standalone or sbc.
      We both run RRF ver 3.3
      This test snippet just tries to declare a local variable inside the loop scope (it's just an example):
      var count = 0
      while var.count < 3
        echo "Hello world. Count:  ", {var.count}
        var param = 42
        echo "Param: ", {var.param}
        set var.count = {var.count + 1}
      ;end while
      Result in a standalone setup:
      2021-10-06 19:03:03	M98 P"0:/macros/test/looptest.g"
      Hello world. Count:   0
      Param:  42
      Hello world. Count:   1
      Param:  42
      Hello world. Count:   2
      Param:  42
      Result in an SBC:
      10/6/2021, 1:13:48 PM    M98 P"0:/macros/looptest.g"
      Param:  42
      10/6/2021, 1:13:48 PM    Error: variable 'var.param' already exists of looptest.g
      Is this known behavior? How is it suppose to work?
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
      Gixxerfast T3P3Tony 2 Replies Last reply Reply Quote 1
      • Gixxerfast
        Gixxerfast @Gixxerfast last edited by Gixxerfast
        Are local variables at all meant to be supported in SBC mode in V3.3
        • T3P3Tony
          T3P3Tony administrators @Gixxerfast last edited by
          @gixxerfast thanks for reporting this. I have confirmed I see the same issue and have let @chrishamm know.
          www.duet3d.com
          • chrishamm
            chrishamm administrators last edited by
            @gixxerfast Thanks for reporting this, I've prepared a bug fix for the upcoming software version 3.4-b5.
            Duet software engineer
