    Wiring 3 SSR's - Request for Direction
    • Chanabra
      Chanabra last edited by
      I have wired a few 3d printer's previously with a SSR controlling them hotbed, the hotbed having a redundant thermistor (seemycnc - drill hole on side of plate and add extra thermistor) as well as a Thermal Cut Off wired with my HighTemp RTV Gasketed 1000W SIlicone hot bed.
      I know it is quite a bit excessive for my hot bed which is 400x400, but I do not wish to buy another. Also, living in the USA, I am at 120V, I almost wish I had bought 220V back when I purchased it and used a step up transformer - anyone hear of any success like that?
      Back to my story: I have one SSR that will be powering the hot bed, I also have a sealed enclosure and a 400W PTC Heater, and a low wattage but mains powered in-line exhaust fan that is going to venting the printer outside when X temperature is reached.
      Because of my 1000W hot bed, I made the assumption that between that, the PTC 400W heater, my inline fan, my 3d printer, all the neopixels, that I should have a separate IEC Cable powering the 1000W Hotbed, 400W PTC Heater and in-line exhaust fan.
      I have this roughly all wired up and I have taken time and care to make sure all grounds are connected where they should be.
      My big question here is: IEC CABLE --> FIltered, Fused, IEC Inlet --> Live WAGO + Neutral WAGO + GND WAGO. Then each wago to the appropriate connections for the 3 SSR's.
      Is it this simple?
      Is there something else I should be doing? Possibly resistors between the wago and the SSR or something?
      I just want to make sure I am doing everything safely. Thank you to anyone who contributes.
      fcwilt achrn 2 Replies Last reply Reply Quote 0
      • fcwilt
        fcwilt @Chanabra last edited by
        @chanabra said in Wiring 3 SSR's - Request for Direction:
        Could you tell us a bit more about what you mean by appropriate connections?
        There are no fundamental problems with the setup but it does need to be wired correctly.
        Thanks.
        • achrn
          achrn @Chanabra last edited by
          Is it this simple?
          Yes.
          Sounds good to me, assuming your wiring size is appropriate, fusing and filtering is sized appropriately.
          WAGOs are good, btw - more reliable than most forms of connector (or maybe, more foolproof - more difficult to do badly / dangerously).
          Not that you should be doing, in my opinion. You don't want to add resistors to the mains wiring.
          You could put a RCD in the system (I think that's probably a GFCI to you, though that's a silly name for it, imo) if you want more protection. Personally, I don't have anything additional for my printers - just the RCD that's on the sockets circuit at the consumer unit (distribution board for the house).
