    Enabling fan tach on expansion board causes fan to disappear
    Firmware installation
    • Hugsy
      Hugsy last edited by
      I (think I) found a bug in the EXP3HC firmware where enabling the tach on a pwm fan causes the fan to disappear.
      M950 F0 C"!1.out4" Q450 ; works fine
      M950 F0 C"!1.out4+1.out4.tach" Q450 ; causes the fan to disappear from dwc and cannot be controlled with M106 commands without having a "Fan number 0 not found" error
      Is my M950 command right? on the MB6HC it works perfectly fine
      MB6HC is currently on RFF 3.2
      Here is a look at my M122 B1 command answer :
      M122 B1
      Diagnostics for board 1:
      Duet EXP3HC firmware version 3.2 (2021-01-05)
      Bootloader ID: not available
      Never used RAM 154808, free system stack 200 words
      HEAT 102 CanAsync 94 CanRecv 84 TMC 64 MAIN 279 AIN 257
      Last reset 00:02:11 ago, cause: software
      Last software reset data not available
      Driver 0: position 0, 80.0 steps/mm, standstill, reads 52709, writes 11 timeouts 0, SG min/max 0/0
      Driver 1: position 0, 80.0 steps/mm, standstill, reads 52711, writes 11 timeouts 0, SG min/max 0/0
      Driver 2: position 0, 80.0 steps/mm, standstill, reads 52714, writes 11 timeouts 0, SG min/max 0/0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0
      No step interrupt scheduled
      VIN: 23.9V, V12: 12.2V
      MCU temperature: min 42.1C, current 42.3C, max 42.3C
      Ticks since heat task active 177, ADC conversions started 131918, completed 131918, timed out 0
      Last sensors broadcast 0x00000000 found 0 180 ticks ago, loop time 0
      CAN messages queued 547, send timeouts 0, received 1198, lost 0, free buffers 36
      Thanks in advance for the answers, Hugh
      T3P3Tony dc42 2 Replies Last reply Reply Quote 0
      • T3P3Tony
        T3P3Tony administrators @Hugsy last edited by
        @hugsy Can you try in RRF 3.3 on your mainboard and expansion board please.
        please read the release notes!
        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
        Also is this in stand alone or SBC mode?
        www.duet3d.com
        • Hugsy
          @t3p3tony The board is in standalone mode. The upgrade to RRF 3.3 for the MB6HC and EXP3HC didn't solved the issue
            dc42 administrators @Hugsy last edited by
            @hugsy said in Enabling fan tach on expansion board causes fan to disappear:
            Change that line to:
            M950 F0 C"!1.out4+out4.tach" Q450
            • Hugsy
              @dc42 Thanks! It works perfectly now
