    Get current job file offset
    Gcode meta commands
    • jbjhjm
      jbjhjm last edited by jbjhjm
      After digging a bit into the resurrect files, I learned that resuming is based on number storing at which byte of file the print should continue.
      I suffered some strange mid-print errors recently so I try to be prepared and extract data required to manually continue printing.
      Object model documentation says there's job.filePosition.
      But when I run a macro containing
      echo job.filePosition
      the response is
      says unsupported type code 5.
      Could not find any info about that response.
      Possibly I have to convert the type of value to something that can be stringified?
      T3P3Tony chrishamm 2 Replies Last reply Reply Quote 0
      • T3P3Tony
        T3P3Tony administrators @jbjhjm last edited by
        @jbjhjm I see this as well in SBC mode, I assume you are running in SBC mode so will report it to @chrishamm
        www.duet3d.com
        • chrishamm
          chrishamm administrators @jbjhjm last edited by
          @jbjhjm Thanks for the report, it's indeed a problem with type conversions in RRF.
          You can use job.filePosition in your scripts without problems but echo fails to print it unless you convert it to an int or string first. These two examples do work:
          echo 0 + job.filePosition
          M118 S{job.filePosition}
          Duet software engineer
          jbjhjm 1 Reply Last reply Reply Quote 1
          • jbjhjm
            jbjhjm @chrishamm last edited by
            @chrishamm works perfectly fine thank you for helping me out!
