    NC Limit Switches
    • Hayden1993
      Hayden1993 last edited by
      Just about to add my limit switches on my CNC (X, Y, Z)
      I've read a fair bit online and it seems better/safer to wire them as NC instead of NO?
      Can I also confirm I'm wiring them correctly on my Duet3 6CH board
      I0_1/2/3
      3.3V = NC
      GND = Gnd
      Hayden
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @Hayden1993 last edited by
        @hayden1993
        Yes NC is better.
        That way the two wires are shorted together thus making interference from another source of electrical noise very unlikely.
        You want to connect the switch NC connection to the board I/O GND and the switch COMMON connection to the board I/O io#.in connection.
        Configure the input for active high.
        Hayden1993 1 Reply Last reply Reply Quote 0
        • Hayden1993
          Hayden1993 @fcwilt last edited by
          @fcwilt much appreciated, thank you
          • droftarts
            droftarts administrators @Hayden1993 last edited by
            @hayden1993 See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
