    Damaged SD card
    • CBDVL
      CBDVL last edited by
      Hi Guys,
      I made a stupid mistake while cleaning and old Delta. I removed the SD card and mistakenly put the chair leg on it......... resulting in it literally breaking in 2 pieces.
      Here are my problems........:)
      I have no backup of the SD card or idea what firmware version I was running
      It is a v1.01 board ?
      is there any way I can get this working again?
      Thanks
      • droftarts
        droftarts administrators @CBDVL last edited by droftarts
        @cbdvl Connect via USB - see https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
        Send M115 to get the current firmware version.
        Recreate the SD card, see https://duet3d.dozuki.com/Wiki/SD_Card for specification, formatting and file structure.
        Use the DWC version from the release that matches your firmware version (unless you update the firmware) - https://github.com/Duet3D/RepRapFirmware/releases
        Use the RepRapFirmware Config Tool to recreate a set of configuration files - https://configtool.reprapfirmware.org/Start
