    Extruder temperature startup problem
    • PennaMirko
      PennaMirko last edited by
      I have a problem that occurs randomly at startup as everything goes smoothly at printer level but does not start the extruder ignition without giving any kind of alarm and stop printing automatically. What can this anomaly cause?
      I attach my configuration file:
      ; Configuration file for Duet Ethernet (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M665 R157 L397.1073 B175 H525 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0.6 ; Put your endstop adjustments here, or let auto calibration find them
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Define active high microswitches
      M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      M557 R130 S20 ; Define mesh grid
      ; BL-Touch
      M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
      M558 P4 X0 Y0 Z1 H20 F200 T5000
      G31 P25 X0 Y0 Z0.2 ; Set Z probe trigger value, offset and trigger height
      M350 E32 I0 ; Configure microstepping without interpolation
      M350 X32 Y32 Z32 I1 ; Configure microstepping with interpolation
      M92 X160 Y160 Z160 E837 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E3000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X39960 Y39960 Z39960 E3000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1500 ; Set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S280 ; Set maximum heater temperature to 285C
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P0 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 F0:1 ; Define tool 0
      M550 PTEVO Little Monster ; Set machine name
      M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      The type of extruder is E3D version 6
      Best regards
      • number40fan
        number40fan last edited by
        You need at least a T0 at the end of config.g,.
          A T0 at the end of config.g will probably fix the issue for the first print you do, but may not fix it for subsequent prints. So a T0 command in the slicer start gcode is normally better. However, recent firmware versions select the tool automatically when a set-temperature-and-wait command is processed. So if you are running firmware 1.17 or earlier, upgrading to a later version may solve it.
