    Connection error to 1XD boards after reset, but OK at power on.
    Using Duet Controllers
    206
    • Marcossf
      Marcossf last edited by
      Hi everyone,
      We have a problem with a printer who has all axis with 1XD boards (XYYZUV), SBC mode and v3.4.0B5.
      When power it on, everything works right after booting up, but if we made a reset or any modification in config.g, after rebooting it shows that:
      Error: M584: Driver 40.0 does not exist
      Driver 41.0 does not exist
      Driver 42.0 does not exist
      Driver 43.0 does not exist
      Driver 44.0 does not exist
      Driver 45.0 does not exist
      Of course, in this moment test each board with M122 B40 to B45 and reports OK all of them (ex. B40):
      m122 b40
      Diagnostics for board 40:
      Duet EXP1XD firmware version 3.4.0beta5 (2021-10-12 13:58:21)
      Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
      Never used RAM 5504, free system stack 2743 words
      Tasks: Move(notifyWait,0.0%,111) HEAT(notifyWait,0.1%,115) CanAsync(notifyWait,0.0%,60) CanRecv(notifyWait,0.0%,75) CanClock(notifyWait,0.0%,64) MAIN(running,96.3%,448) IDLE(ready,0.0%,40) AIN(delaying,3.5%,142), total 100.0%
      Last reset 00:09:25 ago, cause: power up
      Last software reset data not available
      Driver 0: pos -8132, 150.5 steps/mm, steps req 204110 done 180927
      Moves scheduled 785, completed 785, in progress 0, hiccups 0, step errors 0, maxPrep 447, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 5/9, peak Rx sync delay 210, resyncs 0/1, no step interrupt scheduled
      VIN voltage: min 24.3, current 24.4, max 24.4
      MCU temperature: min 21.8C, current 26.2C, max 26.2C
      Last sensors broadcast 0x00000000 found 0 154 ticks ago, loop time 0
      CAN messages queued 4555, send timeouts 0, received 7930, lost 0, free buffers 37, min 37, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 325, adv 35228/98869
      The same with the other boards.
      We have a 3 seconds delay in the config.g to have time enough the boards to start, and increase this time doesn't fix the problem having said when booting from powered off always load them and works.
      This wasn't happening in the beta4 with same configs.
      What can we look for?
      • T3P3Tony
        T3P3Tony administrators @Marcossf last edited by
        @marcossf does sending M98 P"config.g" fix the issue?
        www.duet3d.com
        Marcossf 1 Reply Last reply Reply Quote 0
        • Marcossf
          Marcossf @T3P3Tony last edited by
          @t3p3tony No, it doesn't.
          21/10/2021 10:28:03	M98 P"config.g"
          21/10/2021 10:28:03	PRINTER READY, TRY HOMING ALL
          21/10/2021 10:28:03	Error: M584: Driver 40.0 does not exist
          21/10/2021 10:27:58	Error: M550: Machine name must consist of the same letters and digits as configured by the Linux hostname
          21/10/2021 10:27:58	CORS disabled
          21/10/2021 10:27:28	PRINTER READY, TRY HOMING ALL
          21/10/2021 10:27:28	Error: M584: Driver 40.0 does not exist
          21/10/2021 10:27:23	Error: M550: Machine name must consist of the same letters and digits as configured by the Linux hostname
          21/10/2021 10:27:23	CORS disabled
          21/10/2021 10:27:23	Connection established
          21/10/2021 10:27:19	Connection interrupted, attempting to reconnect...
          DCS has been stopped
          21/10/2021 10:27:18	Upload of config.g successful after 0s
          21/10/2021 10:27:11	Connected to 192.168.2.191:3000
            dc42 administrators @Marcossf last edited by dc42
            @marcossf this is a known issue. If you reset the main board but not the expansion boards, then the expansion boards don't announce themselves to the main board, therefore the main board doesn't know about them. We plan to fix it in release 3.5 or possibly in 3.4 stable.
            The following may resolve it:
            1. In your config.g file make sure you have a M569 command for each remote driver before the M584 command.
            2. In config.g you will have a command something like:
            M569 P40.0 S#
            where # is 0 or 1 s required by your machine. Change it to this, preserving your current S parameter in both M569 lines:
            M569 P40.0 S#
            if result > 1
              M999 B40
              G4 S2
              M569 P40.0 S#
            This attempts to reset the expansion board if the M569 command fails, which will make the board announce itself again, and re-run the M569 command after a delay. Repeat for the other expansion boards.
            Marcossf 1 Reply Last reply Reply Quote 1
            • Marcossf
              Marcossf @dc42 last edited by
              @dc42 OK, we'll try this workaround.
              When do you expect a stable (long term) version to be available?
              • Marcossf
                Marcossf @Marcossf last edited by Marcossf
                @dc42 We added the proposed code to the config.g M569 but it couldn't fix the problem. Still happens.
                M569 P40.0 S1 ; physical drive 40 goes forwards X
                if result > 1
                	M999 B40 ; restart board 40
                	G4 S2 ; wait 2 sec
                	M569 P40.0 S1 ; retry command
                M569 P41.0 S0 ; physical drive 41 goes forwards Y1
                if result > 1
                	M999 B41 ; restart board 41
                	G4 S2 ; wait 2 sec
                	M569 P41.0 S0 ; retry command
                M569 P42.0 S0 ; physical drive 42 goes forwards Y2
                if result > 1
                	M999 B42 ; restart board 42
                	G4 S2 ; wait 2 sec
                	M569 P42.0 S0 ; retry command
                M569 P43.0 S0 ; physical drive 43 goes backwards Z1 (Z)
                if result > 1
                	M999 B43 ; restart board 43
                	G4 S2 ; wait 2 sec
                	M569 P43.0 S0 ; retry command
                M569 P44.0 S0 ; physical drive 44 goes backwards Z2 (U)
                if result > 1
                	M999 B44 ; restart board 44
                	G4 S2 ; wait 2 sec
                	M569 P44.0 S0 ; retry command
                M569 P45.0 S0 ; physical drive 45 goes backwards Z3 (V)
                if result > 1
                	M999 B45 ; restart board 45
                	G4 S2 ; wait 2 sec
                	M569 P45.0 S0 ; retry command
                M584 X40.0 Y41.0:42.0 Z43.0 U44.0 V45.0 E20.0:21.0:22.0                             ; set axis drive mapping
                This only happens with the 1XD boards, the 1LC boards are well detected after the reset.
                A M112+M999 cause the boards were detected fine as well without need to switch it off completely.
                  @marcossf I guess my theory was incorrect.
                  Please can you do the following:
                  1. Power up so that everything is working.
                  2. Send M409 k"boards" and save the response.
                  3. Reset the main board only, in such a way that you get these errors.
                  4. Send M409 k"boards" again and save the response.
                  Then post the two M409 messages in this thread.
                  I've just tried this on a system that includes a single EXP1XD, and in this case after resetting the main board using M999, all boards were recognised including the 1XD. Maybe it's different on your system.
                  Marcossf 2 Replies Last reply Reply Quote 1
                  • Marcossf
                    After power on and sucessfull homing:
                    M409 k"boards"
                        "key": "boards",
                        "flags": "",
                        "result": [
                                "canAddress": 0,
                                "firmwareDate": "2021-10-12",
                                "firmwareFileName": "Duet3Firmware_MB6HC.bin",
                                "firmwareName": "RepRapFirmware for Duet 3 MB6HC",
                                "firmwareVersion": "3.4.0beta5",
                                "iapFileNameSBC": "Duet3_SBCiap32_MB6HC.bin",
                                "iapFileNameSD": "Duet3_SDiap32_MB6HC.bin",
                                "mcuTemp": {
                                    "current": 47.7,
                                    "max": 47.8,
                                    "min": 27.4
                                "name": "Duet 3 MB6HC",
                                "shortName": "MB6HC",
                                "uniqueId": "08DJM-956L2-G43S4-6J9F4-3S46N-TU4QD",
                                "v12": {
                                    "current": 12.2,
                                    "max": 12.3,
                                    "min": 12.1
                                "vIn": {
                                    "current": 24,
                                    "max": 24.1,
                                    "min": 23.7
                                "canAddress": 20,
                                "firmwareDate": "2021-10-12 13:59",
                                "firmwareFileName": "Duet3Firmware_TOOL1LC.bin",
                                "mcuTemp": {
                                    "current": 37.6,
                                    "max": 38,
                                    "min": 25.7
                                "shortName": "TOOL1LC",
                                "state": "running",
                                "uniqueId": "4DXBX-8KANL-M25J0-401GQ-1V40Z-RKLP5",
                                "vIn": {
                                    "current": 23.8,
                                    "max": 23.9,
                                    "min": 11.1
                                "canAddress": 21,
                                "mcuTemp": {
                                    "current": 34.4,
                                    "max": 34.5,
                                    "min": 22.2
                                "state": "running",
                                "uniqueId": "HM418-9LANL-M25J0-401G6-2JD0Z-HLUHQ",
                                "vIn": {
                                    "current": 24.1,
                                    "max": 24.1,
                                    "min": 24
                                "canAddress": 22,
                                "mcuTemp": {
                                    "current": 36.8,
                                    "max": 37,
                                    "min": 25.2
                                "state": "running",
                                "uniqueId": "YN62R-PLANL-M25J0-401G2-J9D0Z-7XPM9",
                                "vIn": {
                                    "current": 24.2,
                                    "max": 24.2,
                                    "min": 24.1
                                "canAddress": 40,
                                "firmwareDate": "2021-10-12 13:58",
                                "firmwareFileName": "Duet3Firmware_EXP1XD.bin",
                                "mcuTemp": {
                                    "current": 30.4,
                                    "max": 30.5,
                                    "min": 23.7
                                "shortName": "EXP1XD",
                                "state": "running",
                                "uniqueId": "SF2PJ-GDA7A-N25J0-40KM4-LNS2Z-76T99",
                                "vIn": {
                                    "current": 24.4,
                                    "max": 24.5,
                                    "min": 24.3
                                "canAddress": 41,
                                "mcuTemp": {
                                    "current": 32.5,
                                    "max": 32.7,
                                    "min": 25.1
                                "state": "running",
                                "uniqueId": "QMG9N-ZHA7A-N25J0-40KMS-K3W2Z-ZB5KL",
                                "vIn": {
                                    "current": 24,
                                    "max": 24.1,
                                    "min": 24
                                "canAddress": 42,
                                "mcuTemp": {
                                    "current": 31.8,
                                    "max": 32,
                                    "min": 23.2
                                "state": "running",
                                "uniqueId": "KYY79-QFA7A-N25J0-40KM0-3NS2Z-ZHMSB",
                                "vIn": {
                                    "current": 24.3,
                                    "max": 24.3,
                                    "min": 24.2
                                "canAddress": 43,
                                "mcuTemp": {
                                    "current": 32.6,
                                    "max": 32.6,
                                    "min": 22.7
                                "state": "running",
                                "uniqueId": "3XP3F-HB9R9-N25J0-40TKU-2PS1Z-RR2JK",
                                "vIn": {
                                    "current": 24.6,
                                    "max": 24.6,
                                    "min": 24.5
                                "canAddress": 44,
                                "mcuTemp": {
                                    "current": 33.2,
                                    "max": 33.3,
                                    "min": 22.8
                                "state": "running",
                                "uniqueId": "F0SDL-N89R9-N25J0-40TKU-K0S1Z-Z90QN",
                                "vIn": {
                                    "current": 24.3,
                                    "max": 24.3,
                                    "min": 24.2
                                "canAddress": 45,
                                "mcuTemp": {
                                    "current": 35.7,
                                    "max": 35.8,
                                    "min": 25.7
                                "state": "running",
                                "uniqueId": "UB3BT-189R9-N25J0-40TK6-L8W1Z-HN3M8",
                                "vIn": {
                                    "current": 24.3,
                                    "max": 24.4,
                                    "min": 24.3
                        "next": 0
                    After reset the board with M999:
                    21/10/2021 18:47:10	M409 k"boards"
                        "key": "boards",
                        "flags": "",
                        "result": [
                                "canAddress": 0,
                                "mcuTemp": {
                                    "current": 47.8,
                                    "max": 47.9,
                                    "min": 47.5
                                "v12": {
                                    "current": 12.2,
                                    "max": 12.2,
                                    "min": 12.1
                                "vIn": {
                                    "current": 24,
                                    "max": 24,
                                    "min": 24
                                "canAddress": 20,
                                "firmwareDate": "",
                                "firmwareFileName": "",
                                "firmwareVersion": "",
                                "mcuTemp": {
                                    "current": 37.7,
                                    "max": 38,
                                    "min": 25.7
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 23.8,
                                    "max": 23.9,
                                    "min": 11.1
                                "canAddress": 21,
                                "firmwareDate": "",
                                "mcuTemp": {
                                    "current": 34.6,
                                    "max": 34.6,
                                    "min": 22.2
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 24.1,
                                    "max": 24.1,
                                    "min": 24
                                "canAddress": 22,
                                "firmwareDate": "",
                                "mcuTemp": {
                                    "current": 36.9,
                                    "max": 37,
                                    "min": 25.2
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 24.2,
                                    "max": 24.2,
                                    "min": 24.1
                                "canAddress": 40,
                                "firmwareDate": "",
                                "mcuTemp": {
                                    "current": 30.6,
                                    "max": 30.6,
                                    "min": 23.7
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 24.4,
                                    "max": 24.5,
                                    "min": 24.3
                                "canAddress": 41,
                                "firmwareDate": "",
                                "mcuTemp": {
                                    "current": 32.8,
                                    "max": 32.9,
                                    "min": 25.1
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 24,
                                    "max": 24.1,
                                    "min": 24
                                "canAddress": 42,
                                "firmwareDate": "",
                                "mcuTemp": {
                                    "current": 31.9,
                                    "max": 32,
                                    "min": 23.2
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 24.3,
                                    "max": 24.3,
                                    "min": 24.2
                                "canAddress": 43,
                                "firmwareDate": "",
                                "mcuTemp": {
                                    "current": 32.7,
                                    "max": 32.7,
                                    "min": 22.7
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 24.6,
                                    "max": 24.6,
                                    "min": 24.5
                                "canAddress": 44,
                                "firmwareDate": "",
                                "mcuTemp": {
                                    "current": 33.4,
                                    "max": 33.5,
                                    "min": 22.8
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 24.3,
                                    "max": 24.3,
                                    "min": 24.2
                                "canAddress": 45,
                                "firmwareDate": "",
                                "mcuTemp": {
                                    "current": 35.9,
                                    "max": 35.9,
                                    "min": 25.7
                                "shortName": "",
                                "state": "running",
                                "vIn": {
                                    "current": 24.3,
                                    "max": 24.4,
                                    "min": 24.3
                        "next": 0
                    Boot console after the M999 reset :
                    21/10/2021 18:46:15	PRINTER READY, TRY HOMING ALL
                    21/10/2021 18:46:14	Error: M584: Driver 40.0 does not exist
                    21/10/2021 18:46:11	Connection established
                    21/10/2021 18:46:07	Connection interrupted, attempting to reconnect...
                    21/10/2021 18:46:07	m999
                    If reset from DWC with M112 + M999, it loads all the tools like the way it does at power on.
                    • Marcossf
                      @dc42 Hi David, have you been able to see this? It's very annoying to be doing resets every time we test a configuration.
                      Is this happening to anyone else?
                        @marcossf please post your config.g file.
                        After you run M999 and get those errors on the console, if you then run M98 P"config.g" do you get the same errors again?
