    EXPERIMENTAL FreeCAD PostProcessor
    CNC
    1.8k
    • PCRundefined
      PCR
      Here is a WiP FreeCAD Path PP.
      some drawbacks
      • Toolchange is always on. So it will always write the T paramter of the tool. If you dont have a toolchanger and want to change tools give the Tool the same number in Path You can now turn the TC on and off with OUTPUT_TOOL_CHANGE = True or OUTPUT_TOOL_CHANGE = False. This command can be given to FreeCAD without the need of modifying the rrf_post.py
      • Tool start with number 1. A tool with T0 is not possible.
      if you want to add a special command before every Toolchange you can do this by modify the rrf_post.py by changing
      TOOL_CHANGE = ''''''            # Tool Change commands will be inserted
      to
      TOOL_CHANGE = '''G333'''            # Tool Change commands will be inserted
      and just FYI
      In RepRapFirmware 2.03 and later, if you try to execute a G- or M-command that RRF does not implement, it will execute a system macro of that name if it exists. For example, if you send G40 then it will execute /sys/G40.g if it exists; and if you send M48 then it will execute /sys/M48.g if it exists. So you can script any custom Gcodes that you need. See https://forum.duet3d.com/topic/14930/m7-... for an example.
      rrf_post.py
      PCRundefined 1 Reply Last reply Reply Quote 6
      • PCRundefined
        PCR @PCR
        @pcr Update to the original post. With some Help from the FreeCAD Forum
        PCRundefined 1 Reply Last reply Reply Quote 1
        • PCRundefined
          PCR @PCR
          @pcr bugfix 20211115
          PCRundefined 1 Reply Last reply Reply Quote 3
          • crapundefined
            crap
            Thanks for sharing this, I'll be trying it out in a week or so. I'm using the GRBL post processor so far which seems to work alright, but I'm sure there will be situations where this is better. I'll probably also be trying some modifications, for an example I've made my own brushless outrunner spindles that are controlled by a servo signal rather than a conventional spindle PWM so it would be great if I could have the postprocessor output
            M280 P'servo number' S'pulselength'
            where rpm is converted to pulselength by the postprocessor, instead of
            M3 S'rpm'
            It would be even better if the firmware would support this, to define spindles that uses servo signals instead of normal PWM. But modifying the firmware is more than I can manage. Also if I modify the firmware I will have to do it again whenever I want to upgrade, whereas a post processor will most likely work the same in the next version of FreeCAD.
            I'll let you know how it works.
            • PCRundefined
              PCR @PCR
              @pcr
              https://github.com/FreeCAD/FreeCAD/pull/5228
              Merged into main freeCAD. To use this you have to use the weekly build till freeCAD will release 0.20
              P-C-R opened this pull request in FreeCAD/FreeCAD
              closed Path | RRF (RepRapFirmware | Duet Boards) PP #5228
              steve123undefined 3 Replies Last reply Reply Quote 4
              • steve123undefined
                steve123 @PCR
                @pcr This commit doesn't seem to be included with the recent build I downloaded:
                OS: macOS 10.16
                Word size of FreeCAD: 64-bit
                Version: 0.20.28671 (Git)
                Build type: Release
                Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
                Locale: C/Default (C)
                I do not see rrf_post.py in the list of the installed post processors at /Applications/FreeCAD.app/Contents/Resources/Mod/Path/PathScripts/post:
                centroid_post.py
                comparams_post.py
                dxf_post.py
                dynapath_post.py
                example_pre.py
                gcode_pre.py
                grbl_post.py
                jtech_post.py
                linuxcnc_post.py
                mach3_mach4_post.py
                nccad_post.py
                opensbp_post.py
                opensbp_pre.py
                philips_post.py
                rml_post.py
                slic3r_pre.py
                smoothie_post.py
                uccnc_post.py
                • steve123undefined
                  steve123 @PCR
                  @pcr Problem was that the cmake file was not updated to include rrf_post.py. That issue has been fixed by this PR: https://github.com/FreeCAD/FreeCAD/pull/6813
                  See also: https://forum.freecadweb.org/viewtopic.php?p=592373#p592373
                  Russ4262 opened this pull request in FreeCAD/FreeCAD
                  closed Path: Add missing post-processor modules [bug] #6813
                  • steve123undefined
                    steve123 @PCR
                    @pcr @dc42 This might be a useful sticky post for the CNC forum.
                    • Phaedruxundefined Phaedrux pinned this topic
