    Laser control with duet 3 1lc or 1hcl
    Laser Cutters
    • make_shake99
      make_shake99 last edited by
      Hello all,
      I'm looking for suggestions on adding a NeJe laser to the custom 3d printer I'm nearing completion on. The printer is an IDEX machine using duet 3 5mini+ with 1lc tool boards controlling each hotend. The hotend mounts are changeable via a quick manual process and I was thinking adding a 3rd toolboard for the laser to swap in for the U tool when needed.
      After reading some of the posts here about lasers, I'm not convinced its worth the effort. It seems a better solution might just to make a purpose built machine with a purpose built controller. I have a bunch of spare parts from making this printer and my cnc machine.
      Would anyone like to share their advice??
      Thanks in advanced
      https://neje.shop/collections/all-products/products/30w-laser-module
      o_lampe 1 Reply Last reply Reply Quote 0
      • o_lampe
        o_lampe @make_shake99 last edited by
        @make_shake99 It's OK for occasional wood engraving, but it produces a lot of dust.
        For regular cutting I'd build a dedicated machine.
        make_shake99 1 Reply Last reply Reply Quote 0
        • make_shake99
          make_shake99 @o_lampe last edited by
          @o_lampe Thanks for the feedback, I didn't think about the dust.
          • rjenkinsgb
            rjenkinsgb last edited by
            Could you use something similar the dust collector / cutter shroud part from the E3D ASMBL tool with the laser?
            That would both provide some protection from reflections and allow you to use a vacuum collector for dust removal, to keep the cutting area clean.
            https://www.thingiverse.com/thing:4206827
            Robert J.
            Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
