    Bed Heater missing as a tool
    Firmware installation
    164
    • humbleJoe
      humbleJoe last edited by
      Hi all,
      I have recently repaired my duet 2 ethernet board after my U3 Chip died (because of a loose cable which I also fixed). After the repair the board and 5v (3.3v) looked fine again and i could start the printer without any issues. All the functions look fine for me as well (Homeing, heating up the tool heater,...) howerver for some reason i am now missing the bed heater in my dashboard.
      Does anyone know why this error now appeared? I have not changed anything on my firmware so it is kind of strange that this now happend.
      Duet Web Control 3.2.2
      Duet Ethernet 1.02
      RepRapFirmware for Duet 2 WiFi/Ethernet 2.03 (2019-06-13b2)
      config g:
      M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S275 ; set temperature limit for heater 1 to 275C
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @humbleJoe last edited by
        @humblejoe
        Do you have a M140 command somewhere?
        Your firmware is rather old and is out-of-sync with the Duet Web Control version. You may want to think about updating both to 3.3.
        humbleJoe 1 Reply Last reply Reply Quote 0
        • humbleJoe
          humbleJoe @fcwilt last edited by
          @fcwilt
          I dont have M140 command in config.g, config-override.g or bed.g. I have not checked the rest but i guess it should be in config.g.
          What exactly do I need to add, just M140? I guess there are some parameters as well ^^
          And I still dont get why this was not necessary bevore 😮
          To the out of sync firmware I must admit that I am a very lazy person and I realy like the fact that for the last year I could always just use my printer without any changes and never had to adjust anything (apart from retensioning the belts). The best printer is the one that works 😛 .
          But I will look up the changelog and see if there are important changes and update the firmware then.
          Greetings
          Joe
          • fcwilt
            @humblejoe
            Here is how my heated bed configuration looks from my config.g file which is for version3 firmware:
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138             ; configure sensor 0 as thermistor
            M950 H0 C"bedheat" T0 Q10                                  ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 B0 S1.00 A107.3 C136.0 D2.8 V12.0                  ; values A, C, D, V determined by running heater tuning
            M140 P0 H0                                                 ; map heated bed to heater 0
            M143 H0 S115                                               ; set temperature limit for heater 0
            The M308 and the M950 don't apply to you since you are running v2 firmware. M950 is not used at all in v2 and M308 in v3 is M305 in v2.
            The important part is the M140 which says that heater 0 (the H0 parameter) is the heater for the bed (the P0 parameter)
            I believe that even in v2 firmware the M140 must come before the M143 as is done here.
            • humbleJoe
              humbleJoe @fcwilt last edited by humbleJoe
              @fcwilt
              I have tested the M140 but it did not change my issue. So I desided to update to latest stable FW 3.3 and downloaded the Duet2and3Firmware-3.3.zip from there. I used the System/Upload System files and after the upload and decompression it installed the updates without any error mssg. However in diagn. it still shows me that my firmware is 2.03 from 2019.
              Is it not possible to upgrade the reprap firmware like this? I thought that this is the recommended way to do an update.
              But at least it looks like a "Bed-Heater" is now recognized at least. However there are some things wrong I guess.
              I will check first if there is realy no connection on the Bed temp sensor,... but does anyone know why there is now shown 8 Heaters in chart?
              Here is the feedback to M122:
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet Ethernet 1.02 or later
              Board ID: 08DGM-917NK-F2MSW-6JKF2-3SN6K-1G6NG
              Used output buffers: 1 of 24 (6 max)
              Static ram: 25680
              Dynamic ram: 93324 of which 0 recycled
              Exception stack ram used: 388
              Never used ram: 11680
              Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
              Owned mutexes:
              Last reset 00:06:07 ago, cause: software
              Last software reset at 2021-10-25 19:56, reason: User, spinning module GCodes, available RAM 11836 bytes (slot 0)
              Error status: 0
              Free file entries: 10
              MCU temperature: min 24.4, current 25.2, max 25.4
              Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, SG min/max 0/214
              Driver 1: standstill, SG min/max 0/180
              Date/time: 2021-10-25 20:02:11
              Cache data hit count 863568591
              Slowest loop: 4.82ms; fastest: 0.07ms
              Hiccups: 0, FreeDm: 169, MinFreeDm: 167, MaxWait: 10059ms
              === DDARing ===
              Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 5.11ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              Interface state 5, link 100Mbps full duplex
              • fcwilt
                @humblejoe
                To get to ver 3.3 from ver 2.x you have to make a brief "stop" along the way at ver 3.0.
                It mentions the details here:
                Installing and Updating Firmware
                humbleJoe 2 Replies Last reply Reply Quote 0
                • humbleJoe
                  @fcwilt
                  Thanks for the info - i will try.
                  The Heater was realy missing because I was to dumb to connect the thermistor correctly. It now shows the temp again and works with some ugly additions.
                  This might had been the issue in first place, that he coudnt measure any resistance at the bed thermistor.
                  • humbleJoe
                    humbleJoe @humbleJoe last edited by
                    Update:
                    Firmware Update was successful. I had to adjust some commands (RRF Config tool helped me a lot there).
                    And after correcting the connection error at the bed thermistor everything works now as intended and the charts are now looking fine as well. Thanks for the support @fcwilt !
                    Have a nice day 🙂
                    Sincerely
                    Joe
                    • humbleJoe
                      @fcwilt
                      One more thing - i was happy too early:
                      I have now the issue that my bed "heats up to slowly".
                      As fas as my multimeter tells me the 100k @ R25 are correct.
                      M550 P""                             ; set printer name
                      M918 P1 E4 F2000000                                ; configure direct-connect display
                      M551 P""                               ; set password
                      M552 P192.168.0.254 S1                             ; enable network and acquire dynamic address via DHCP
                      M569 P0 S1                                         ; physical drive 0 goes forwards
                      M569 P1 S0                                         ; physical drive 1 goes backwards
                      M569 P2 S0                                         ; physical drive 2 goes backwards
                      M569 P3 S1                                         ; physical drive 3 goes forwards
                      M584 X0 Y1 Z2 E3                                   ; set drive mapping
                      M92 X80.00 Y80.00 Z400.00 E136.45                  ; set steps per mm
                      M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
                      M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
                      M208 X235 Y235 Z260 S0                             ; set axis maxima
                      M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                      M574 Y1 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                      M574 Z1 S3                                     ; configure sensorless endstop for low end on Z
                      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                      G31 P500 X42.5 Y-8 Z2.4                            ; set Z probe trigger value, offset and trigger height
                      M557 X50:200 Y50:200 S20                       ; define mesh grid
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4400 ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                        ; map heated bed to heater 0
                      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4400  ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                      ;M143 H0 S115                                               ; set temperature limit for heater 0
                      ;M305 P0 T100000 B4092 R4700                        ; set thermistor + ADC parameters for heater 0
                      ;M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                      ; BLTouch - Heaters
                      M307 H3 A-1 C-1 D-1 				   ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
                      M106 P0 S0 I0 F500 H-1                             ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M106 P1 S1 I0 F500 H1 T45                          ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M106 P2 S1 I0 F500 H1:0 T45                        ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      T0
                      What am I missing / do i need to correct with the new FW
                      fcwilt Gixxerfast 2 Replies Last reply Reply Quote 0
                      • fcwilt
                        I have added some comments in relation to parts of your config.g file - this is NOT your entire file - you should edit your existing file.
                        ; if you put the M92 before M350 and the values in M92 are correct for X16 microstepping
                        ; any changes you may make later to M350 will internally change the steps-per-mm as needed
                        ; there is a short form for M208 you can use - the number before the : is the min, after the max
                        M208 X0:235 Y0:235 Z0:260
                        ; are you really using stall-detection on your Z axis?
                        ; it doesn't look like you have run heater tuning (M303) as the M307 commands are missing the parameters the tuning would tell you to add
                        ; M305 is used with v2 firmware - why is it here?
                        ; M307 like this is used with v2 firmware - remove it
                        ; BLTouch - Heaters
                        ; you have fan 1 for heater 1 - you have fan 2 for heater 1 and 0 - is that correct?
                        • Gixxerfast
                          Gixxerfast @humbleJoe last edited by
                          @humblejoe I guess you have to do a PID calibration https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                          I had the same before I knew I had to do one 🙂
                          Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                          Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                          Ender 3 Pro with BTT SKR-2 + RRF
