Use 5v from diffrent source for optical endstops? on duetwifi
What that means is that if your endstop has a 3-wire connection, then you shouldn't power it from 5V because we can't guarantee that the endstop inputs will tolerate 5V.
Understood, thanks for the clarification.The simplest option may be to change the resistor on the endstops. Can you provide some close-up photos of them?
I turned out that I wired the simple microswitch endstops the wrong way
But not all issues solved. I don't know if its related to logic level or not. Maybe you can help. This is the touch plate I am trying to setup:
The LED on the Duet Z-Axis endstop is fully lit, and when I close the circuit the blue LED on the sensor lights up, but the Duet LED status does not change. All 3 connections are wired. Unfortunately, there are no specs available (was sent to me by routakit) and I have no idea how to proceed.....in config.g I have setup the probe with M574 Z0 S2Unrelated question: is there a gcode to test for the status of filament runout sensors (configured with M591)?
One more for the Duet V3 wishlist: As stated here C5 thru C9 (the endstop inputs on the DueX) cannot be used for filament monitors, but C10 and C11
Is that correct? Even if a simple microswitch were to be installed for sensing? Renders 3 drivers of the DueX5 pretty much useless to my setup...By the way: your response time is just mind-blowing. Have you been waiting for my post??
@googliola said in Use 5v from diffrent source for optical endstops? on duetwifi:
It's difficult if you have no data for the probe. It might work if you use it as a Z probe instead, connected to the Z probe input, with P5 or P8 in the M558 command. Check the Z probe reading in DWC to see whether the firmware is reading the output.
Yes, M591 D# where # is the extruder drive number.
Is that correct? Even if a simple microswitch were to be installed for sensing? Renders 3 drivers of the DueX5 pretty much useless to my setup...They should be OK for simple microswitch sensing.
I know it's a old post, but I didn't want to create a new one just for 1 question.
I have adapted a Duet2Wifi v1.04 on ATOM 2.5EX Delta printer, and I have a question about optical limit sensor.
The sensors are OMRON trade parts and were connected on +5v on the old board.
The sensor didn't work with +3.3v on the duet, then I need to go to +5v external powerMy question is simple, can I just connect the signal pin on the Duet and no connection for the +3.3v and ground pin or need I connect signal pin + ground pin on the duet board.
I would like to connect +5v and ground on the adapter below and just the sensor signal pin to the duet board.
Is it possible ?Thanks for your support.
@StAnZ-007 said in Use 5v from diffrent source for optical endstops? on duetwifi:
Is it possible ?you'd need to ensure the output- is connected to ground on the duet. usually input- and output- are the same, so if you feed it Vin from the duet that should be okay. then verify the duet inputs are okay with the signal level, no idea of they active high or low, or if the duet can take 5v on all inputs.
@bearer said in Use 5v from diffrent source for optical endstops? on duetwifi:
The sensor are active high.
If I found good information here, duet board v1.04 can accept +5v on sensor inputs -
then make sure you have a common ground and you'll be golden with your plan
Thar adaptor is overkill. You can get +5V from either the PanelDue connector or from the expansion connector. And yes, the Duet WiFi/Ethernet rev 1.04 tolerates 5V on the endstop inputs.
@dc42 said in Use 5v from diffrent source for optical endstops? on duetwifi:
OK, if I use the +5v from pin 1, can I give the power to 5 sensors at the same time on the Pin 1 alone ?
Yes.
Yes.
Thanks for your fast answer.
So last question,
- Can I connect all my 5v sensor pin to the expansion pin 1 ? => OK, it's clear for me
- Then can I connect all my ground sensor pin to the expansion pin 2 ?
- Then can I connect only signal to X Stop / Y stop / Z stop / E1 ans E2 stop ?
Possible or not ?
Thanks
Yes, that's workable.
Nice, thanks
Hi all,
I also have problems with the optical endstops. The board I have is the Duet2Wifi v1.04 and the endstops are TCST2103 5v optical sensors (https://www.vishay.com/docs/81147/tcst2103.pdf).
VCC is connected to 5v Powersupply
GND to GND on the endstop-pin on the Board
SIG to STP/IN on the endstop-pin on the BoardThe endstops are in the config.g File set to Active-High (M574 X2 Y2 Z2 S1).
If the sensors are triggered, the endstop LEDs on the board go out. But nothing happens in web control -> it shows all sensors are triggered.
No i have measured the sensor signals:
If the sensor is triggered, the output is 4.3v
If the sensor is not triggered, the output is 1.5v, and not 0v or GND...Have I missed something or are my sensors just crap?
Thanks for Help.
@KroVex said in Use 5v from diffrent source for optical endstops? on duetwifi:
Hi all,
Thanks for Help.
The datasheet you linked to is for a bare slotted opto sensor, and as such it does not require 5V. But it does need sufficient forward current in the IR diode to turn the phototransistor fully on. Please provide the schematic of the complete endstop device that uses that sensor, including the values of the resistors on it (there are probably 2 of them).
I could not find the original data sheet because the manufacturer (germanreprap.com) has closed its forum.
But maybe the pictures will help:
Three resistors are installed on the back of the sensors: 1002, 1800, 2200
Problem solved!
A good tip was that the sensor does not need 5v.
However, the homex / y / z.g files from e.g. G1 H2 Z5 F6000 must be changed to G1 S2 Z5 F6000 (H to S). Now the motors stop when the sensor is triggered.Thx for Help.
Then you must be using quite old firmware.
The board I have is the Duet2Wifi v1.02 and the endstops are most likely 5v (see pic), so no luck with that combo. I read somewhere in this forum that it is possible to convert them to 3.3v by adding a resistor. My know-how for these things is close to zero, so could anyone point me to right resistor and what Ohm I need to add (on top of SMD resistor)?
That endstop may work on 3.3V already. If it doesn't, then I suspect that R1 is the critical component. The picture is a little out of focus, so I can't read the label on it - what is it? Can you measure its value with a multimeter?
