    firmware 3.2 to 3.4 update
    Firmware installation
    • A Former User?
      A Former User
      hello friends i would like to update my firmware from 3.2 to 3.4 can you tell me if there are any changes to be made in the config?
      • T3P3Tonyundefined
        T3P3Tony administrators @A Former User
        @sgk
        Before you upgrade to 3.3 see this change log:
        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
        once you are on 3.3 then you can look at upgrading to 3.4b5, using this change log
        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta-&-RC
        Note due to an issue with how the upgrade from 3.2 to 3.3 works, I recommend that you do the following method for upgrading from 3.2 to 3.3 (assuming you are running in standalone mode, if you are using SBC mode then reply and i will point you in the right direction for that.)
        1. get Duet2and3Firmware-3.3.zip from the 3.3 release and upgrade through DWC
        2. Once the upgrade is complete check that the mainboard and all expansion boards are upgraded to 3.3, along with DWC. if they are the move on to #3, if not then use M997 to upgrade the boards that are not upgraded
        3. Upload the Duet2and3Firmware-3.3.zip again this will cause the correct /firmware directory to be made for further upgrades
        4. Now you can upgrade to 3.4b5 (after checking the release notes.
        www.duet3d.com
        • A Former User?
          A Former User @T3P3Tony
          @t3p3tony yes ok thank you
          I'm going to start
