    Duet 3 6HC board for cnc
    CNC
    • weed2all
      weed2all last edited by weed2all
      Just some findings about duet 3 board wired on a small 400x400x100 cnc...what I find till now...no matter the build in drivers can drive big stepper motors because the eliminating factor is the voltage input...on my cnc with leadscrew( 8mm lead) at 24v I can only drive the machine at 2400mm/min more than that my nema24 3.1 N.m. motor stalls..
      With 30v I could bump the speed up untill 3000mm/min...the testing didn't stop here...I have a few skr 1.3 boards with wifi module and I install reprap firmware on one of them and i use some chinese JMC 2M542 drivers along with 48v psu...and wow...what a speed jump...I can get 8000mm/min with the same motors...with all of this the next step I think is to sell my duet 3 board...as I bought it on purpose for this cnc...
      Hope someone find this usefull...
      I made 2 short videos with duet3/24v and skr1.3/48v
      Duet 3 2400mm/min or 40mm/sec
      https://youtube.com/shorts/ImlCNQgS-T8?feature=share
      Skr 1.3 and 2m542 drivers at 8000mm/min or 133mm/sec
      https://youtube.com/shorts/M7swwwzUWAw?feature=share
      https://www.thingiverse.com/weed2all/designs
        dc42 administrators @weed2all last edited by
        @weed2all what is the specification of your Nema 23 motors, and what steps/mm do your axes have?
        weed2all 1 Reply Last reply Reply Quote 0
        • weed2all
          weed2all @dc42 last edited by
          @dc42 I've testes 1/8 and 1/16...no much difference here...I've settle at 1/16 on most tests I made...
          Oriental Motors
          Model number : PK269 JDA
          Basic Step Angle : 1.8˚
          Holding Torque N·m : 3.1
          Current per Phase A/phase : 2.8
          Voltage V DC : 4.2
          Resistance per Phase /phase : 1.49
          Inductance mH/phase : 5.7
          • T3P3Tony
            T3P3Tony administrators @weed2all last edited by
            @weed2all and what did you have the M92 command set to?
            www.duet3d.com
            • weed2all
              when test made with 1/8 I had M92 set to 200...
              On most tests at 1/16 I have my M92 set to X400 Y400 Z400
