    Nimble mount…
    Filament Monitor
    1.9k
    • DjDemonDundefined
      DjDemonD
      So has anyone (Lykle?) come up with a bracket to fit this above a nimble yet? I'm trying to conjure one now, and finding it awkward?
      www.precisionpiezo.co.uk
      • Dougal1957undefined
        Dougal1957
        to fit what above a nimble Simon
        • DjDemonDundefined
          DjDemonD
          filament monitor.. sorry i posted this in the filament monitor forum…
            Dougal1957
            Ah did wonder but there is nothing to actually show which sub section it is in Ah I see it now totally missed that info
            I think I will be fitting onewhere the filament enters my feed tube know it isn't the best place but think it will be ok there and until we actually have one it will be hard to do anything ref a mount anyway
            Doug
            Hopefully meet up at TCT on the 27th
            • DjDemonDundefined
              DjDemonD
              Yes that would be great.
              I am printing a mount now but its a bit rough and ready..
              • DjDemonDundefined
                DjDemonD
                Well got there in the end. Mounted now to wire it up and play.. but first many things to print 😞
                • T3P3Tonyundefined
                  T3P3Tony administrators
                  Ahh cool looking good - how does it work?
                  www.duet3d.com
                  • DjDemonDundefined
                    DjDemonD
                    Haven't got that far yet.
                      Dougal1957
                      how does it impact on the breach looks like it may be tight in there especially for fat figures like mine
                      • DjDemonDundefined
                        DjDemonD
                        Not too bad, but not quite as easy to load. You could mount it higher up, probably have to reinforce my mount somewhat. Will post the mount when I'm not on my phone.
                        • DjDemonDundefined
                          DjDemonD
                          I wired it up but haven't yet calibrated it, but it reads the angle so it's working.
                          One thing might be worth doing is just stating which wire is which on the filament monitor PCB. The silkscreen is obscured by the 3 pin connector so isn't easy to read.
                          EDIT - I probably should explain that this is necessary for me as I don't use Molex plugs but use standard DuPont "endstop leads" and they are not polarised, but they are readily available, cheap and I have a great many of them lying around.
                          • DjDemonDundefined
                            DjDemonD
                            moved to another thread not mount related.
                            • DjDemonDundefined
                              DjDemonD
                              Okay so the mount broke, it's too thin, in the area of the ring that attaches it to the Nimble under the drive cable. So I have added a spar to see if it helps and will try it again. Will post it if it works.
