    Ability to store fan speed?
    Using Duet Controllers
    • obzocker
      obzocker last edited by
      Is there an Ability to store the current fan speed? I want to modify the
      "pause" and "resume" so that i can turn the fan off when paused and resume with the fan speed that i saved.
      cosmowave OwenD zapta 3 Replies Last reply Reply Quote 0
      • cosmowave
        cosmowave @obzocker last edited by
        @obzocker Yes. You can store the fan speed value in a variable...
        Mankati FSXT+, DeltaTowerV2, CBot3D
        • OwenD
          OwenD @obzocker last edited by OwenD
          @obzocker
          What firmware are you running?
          Perhaps also post pause.g and resume.g
          You can restore fan speeds , but there were changes in V3.3
          Previously the command M106 R (with no P parameter and no value after R) would restore the last saved default print cooling fan speed, and if you did supply a value after R then that value was ignored. Now it is mandatory to specify a restore point number after R.
          Fan speeds are no longer restored automatically when resuming a print. If you change the print cooling fan speed in pause.g, restore it in resume.g using M106 R1.
          • zapta
            zapta @obzocker last edited by
            Is it possible to do that without saving fan speed? E.g. on pause set max fan speed to 0 and on resume back to 100%?
            cosmowave 1 Reply Last reply Reply Quote 0
            • cosmowave
              cosmowave @zapta last edited by
              @zapta Yes. Set your fan to 0% at the beginning of pause.g, and back to 100% at the end of pause.g.
