    Maestro stepper expansion and pt100 daughterboard
    • jphilly
      jphilly last edited by
      On a maestro these 2 board overlap real estate, so one has to be on a riser for both to be installed. Which would be better to put on a riser/ does it matter? Currently I have the drivers on a riser (maybe 15-20mm up)
        dc42 administrators @jphilly last edited by
        @jphilly it would be better to put the SPI daughter board on a riser, because if the drivers are on a riser then the high ground currents when the motors are driven could cause noise issues.
